Hi,
neither all standard styles nor any user defined styles are displayed in the home menu. As far as I know there is no other way to assign a style template to a pragraph.
It happens in v. 7.5 and 8.0. Screen resolution is 1280x1024
OS version: Linux Mint 20.3 Una, base: Ubuntu 20.04 focal
App version: ONLYOFFICE Desktop Editors, Version 7.5.1.23 (flatpak)
and: version 8.0.0.99 (deb)
I experimented a little more and found out, that it must have to do with the document I imported into OnlyOffice. Most of the templates of the original file are now missing in the menu. They are still there somewhere, because they are shown in the context menu âFormatting as style â Update â
Hi Nikolas,
I loaded up a sample file (I had to export the original odt-file with LibreOffice to Word doc-file to be able to open it with OnlyOffice. Originally it had 36 pages with many pictures).
As you can see, only a small amount of styles are shown:
But the text is formatted in 4 different styles:
Rad_Ăberschrift1, Rad_Standard, Rad_Standard_klein anbd Rad_PLZ.
But you can see these styles only in the context menu (but can not assign it to the text):
Possibly it is a bug in the word file itself. At least I cannot reproduce this error with other (smaller) files.
Hi Nikolas,
Iâm sorry, the original odt-file has 125MB and when I reduce it to the single page like my sample file, it is no problem to import it into OnlyOffice. So either it is the size of the file or there is a bug in the file. I think it is not necessary to investigate any deeper, what do you think?
Best regards
Martin
hey @ToxyLT
If you could provide us with the file for testing the issue, we would greatly appreciate it. Weâll make every effort to identify the problem and fix it.
I have the same problem uploading .docx from google docs mapped to gdrive under linux mint (Iâm thinking of moving from google docs to onlyoffice workspace). My earlier documents work fine, created in google docs 2021 and earlier. The docs created in years 2022, 2023, and 2024 all have this problem. I noticed it as I uploaded because if I had âDark Documentâ set then the uploads looked blank but turning off âDark Documentâ they were then readable. The early google docs uploaded did not have this problem. Let me know if there is a solution I can use/quick fix. I have examples, but Iâm a new user and canât upload. Thanks!
Thanks for the details, and we really appreciate you choosing OnlyOffice!
You should now be able to upload files. It would be awesome if you could share one of the problematic documents and maybe a quick video showing the steps you followed to reproduce the issue. That would really help us figure out whatâs going on!
Document A is downloaded directly from Google Docs to my PC. Document B is how it looks in onlyoffice after import.
Styles such as âNormalâ are missing and in particular if I have Dark Document theme turned on, the Document is unreadable until I turn the Dark theme off. I did notice looking at other Google Docs I downloaded but work that often the âNormalâ style is missing, but the âDark Documentâ setting works as expected.
I created the simple document in Google Docs. Uploaded to onlyoffice and the problem occurs. The documents I created in years 2021 and earlier do not have this problem. All documents I tried created in 2022 or later, all have this Dark Document issue. All documents seem to be missing styles such as âNormalâ but not always missing âNormalâ.
One update. The issue with Dark Documents not showing in light mode goes away after an update to the document. So I put in a small change, let it version itself, and pull it back up and the Dark Documents theme now works as expected.
@Ecurb
Thank you for the detailed information. Weâve forwarded the details regarding the missing styles issue to our team for investigation.
To better understand and diagnose the issue youâre experiencing with the âDark Documentâ theme in onlyoffice, could you please provide a screen recording of the problem occurring?
Steps: created a simple document in Google docs. Exported it by Download .docx. Uploaded it to onlyoffice. Image 1 shows the unedited document with âDark Documentâ enabled. Image 2 shows the unedited document with âDark Documentâ disabled.
Thank you for your detailed report and for providing all the necessary information. We were able to reproduce the issue youâre experiencing, specifically regarding the bug where not all style templates are visible in the home menu.
We are currently working on reproducing the problem with the Dark Document theme and will keep you updated on our progress.
Thank you so much for your contribution to the development of ONLYOFFICE! If you encounter any bugs in the future, please donât hesitate to reach out. Your detailed reports are incredibly valuable and help us improve the product.
To confirm, we have successfully reproduced the issue you described, specifically the incorrect application of the âDark Documentâ mode in the .docx file created in Google Docs.
Unfortunately, I canât provide a timeline for the fix just yet.
I would like to provide my input on this issue.
I recently migrated many documents from Google Drive to NextCloud. Iâm using OnlyOffice Docs (7.3.0.184) to edit documents.
I got same issue as reported by @ToxyLT : a Google Document imported doesnât have all these titles and it doesnât seem possible to recreate titles from existing ones.
In order for you to replicate, you can use following steps :
Create a Google Docs
Create several titles (Title, Title 1, Title 2, Title 3)
On the screenshot, you can see table of contents is still here.
However, if you want to create a new title with style âTitle 2â, itâs not doable and itâs not possible to add it to table of contents.
I found a workaround to find back titles :
Open document imported with LibreOffice writer (on my computer)
Make a small change and save
Open back your document with OnlyOffice
=> Titles are now present and you can use it
I didnât check yet if the issue is only on Google Docs created before 2022 as mentioned by @Ecurb
If you have any ideas about a workaround, I will appreciate.
Thank you for your feedback and for sharing your workaround!
The issue you described has already been reported some time ago, and we appreciate your detailed input on it.
Unfortunately, we donât have any updates on the fix timeline yet.
In the meantime, your workaround with LibreOffice may be helpful to other users experiencing the same problem.
Thanks fort your reply @Nikolas
My workaround is working but when you have tons of files with that bug, itâs a bit long.
Do you have another workaround to provide or something I can try ?
