Working in Only Office v.8.2.143
Hello, I created a table at work in the Only Office program, saved it, then opened it and to my surprise, frames appeared around words and invisible symbols. How to get rid of them? Thanks!
Hello @SeCarp
I believe you are describing the issue as in this topic:
If so, then please update your Document Server to the actual version 8.2.2.
Thanks for the reply, I hope it helps.
It really helped! Thanks a lot.
I am glad to know. Closing the topic as solved.
