Word processor - when not visible, table pasting option dialog is not active
Hello
New bug in 8.0.
The file:
bug with table pasting options depending on zoom level.docx (24.7 KB)
the video:
The scenario:
  • I have a table with several colums
  • I want to embed it in another table
  • I copy it
  • then I paste it in the target cell of the other table.
When the zoom level is low and allows to display the "table pasting option dialogue " (or whatever the name of it), I can do CTRL then N to embed the copied table.
However, when the zoom level is high and the table pasting option dialogue is not visible, then, CTRL + N is not working :frowning:
PS : What I call “table pasting option dialogue” is this:
Thanks for studying this case.
Hey @arcqus :handshake:
Thank you for the video and the file! :blush:
We are checking the situation.
I will let you know when I get something.
We have reproduced the issue you described and have created a bug report.
@arcqus, thank you for contributing to our product. We really appreciate it! :hugs:
