Do you want to: Report a bug
OS version: macOS 12.7.6 (21H1320)
App version: 8.3.1
Additional information:
If using keyboard shortcuts such as ⌘ + Up/Down (which move the selector multiple cells at once), the visible portion of the sheet does not follow the selected cell.
Am also finding that even when moving the selector one cell at a time, the view eventually falls behind and the selected cell leaves the visible area of the sheet.
Expected behavior is that the view will update to show the currently selected cell.
(Looked but could not find a setting to adjust this).
recordings attached.
Hello @kjdfngrt
I wasn’t able to reproduce the situation with this version of Desktop Editors. I believe more information is required:
- Do you use graphics acceleration in the settings of the editor?
- Does it happen with all files or this particular one?
- Which chip is your device running? It is Apple Silicon or Intel chip device?
Hi @Constantine,
In looking again, I believe issue correlates to when row height is larger than the default.
Here is the test workbook.
testing2.xlsx (14.8 KB)
You see the issue with the sheet with larger row heights, but not in the sheet with rows that are default height.
(Machine is an Intel. I cannot find a graphics acceleration option in the settings).
Thanks.
Thank you for the file. We will analyze the situation and I will let you know the status.
I was informed that this issue has been registered earlier as a bug. Your query was added to the bug. Sorry for the inconvenience.
Hi @Constantine,
No worries. Thanks for the update.
Hi @Constantine,
Just checking in on this. Confirming this is still an open bug in v8.3.3? (I’m continuing to encounter it).
If there’s a github issue link available, I’m happy to just track it there.
Thanks.
Unfortunately, it is indeed still opened.
Okay thanks, just confirming.
