Our team installed onlyoffice docs version 7.0 on Centos 8.4 system (without using docker), trying to use the token function but there is a problem with the work.
First, set up the local.json file according to the documentation and restart the onlyoffice docs service.
Secondly, after running the provided demo(JAVA Spring Example), he did not successfully open the page as expected. An error message was issued:
“The document security token is not correctly formed.Please contact your Document Server administrator.Press “OK” to return to document list.”
(Because of the limitation of the link for new users,Completed in comments!)
