the service provider responsible for our OnlyOffice installation has updated the software. This new version requires a Json Web Token.
So I started digging to implement this token, but I don’t understand how it works, and especially what information to put in the payload. I manage to access the document with an empty token, but the edition no longer registers and I have a WebSocket error :
sockjs.min.js:2 WebSocket connection to ‘wss://onlyoffice.my_address.fr//7.0.0-132/doc/a733a6/c/069/xhxl5g1r/websocket’ failed:
The JWT used :
The javascript config is generated with php (Laravel blade template) :
config = {
"document": {
"fileType": "{{ $file->name }}".split(".").at(-1),
"key": key,
"autosave": false,
"title": "{{ $file->name }}",
"url": "{{ $address }}",
"documentType": doctype,
"editorConfig": {
"mode": "{{ $mode }}",
"callbackUrl" : "https://my_address.fr/callback.php?url={{ $callbackParam }}",
"lang" : 'fr',
"customization": {
"logo": {
"image": "https://my_address.fr/logo.png",
"url": "https://my_address.fr"
"height": "100%",
"width": "100%",
"token": "eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.e30.5IuXpdN4fObi2fx6W5CGCNoz6SJXz8Kvjc1n15krGFo"
window.docEditor = new DocsAPI.DocEditor("placeholder", config);
The JWTs listed in the OnlyOffice documentation cause an invalid token error.
https://api.onlyoffice.com/editors/signature/request
Several questions :
- My service provider has set up a password, where am I supposed to enter it?
- Does the Json Web Token have to have a precise signature or can I put any character string?
- How to make the Json Web Token have all the permissions, and that it is the same to view, edit, co-edit etc a document (the permissions are managed upstream in PHP)
You would be of great use to me if you helped me a little bit, it’s the first time I’ve used JWTs and all of this is not very clear to me…
Thank you very much !
