workspace V12.0.0.1726 script docker installation and nextcloud 24.0.1 snap installation
When configuring ONLYOFFICE app in nextcloud the error is:
cURL error 60: SSL certificate problem: unable to get local issuer certificate (see libcurl - Error Codes ) for https://editor.officegroup.it/healthcheck )
Carl
19 June 2022 21:36
2
Document Server from ONLYOFFICE Workspace cannot be integrated with other document management systems. I recommend installing a separate Document Server for this purpose:
https://helpcenter.onlyoffice.com/installation/docs-community-index.aspx
As for the certificate issue, please enable the ‘disable certificate verification’ option in the connector settings and check if the issue persists.
