Hi
Green is tipped as “orange” instead of “vert” in french:
The file was created with MSO. bug in the colour palette.xlsx (16.6 KB)
After a little more analysis, the issue seams to be related to the colour template chosen for the file, because with a file created with OO, no issue:
(check the difference in the colour organisation in the colour palette)
Hello @arcqus
Unfortunately, I’m not able to reproduce the situation with provide file. I have tested it on Windows 11 with Desktop Editors v.7.4.1. It seems that translation is correct.
Should I run some specific steps to achieve the same result as on your screenshot?
No longer there with 7.4.1.
Either a glitch in the matrix, or an issue with my file, or an issue with OO previous version.
I guess you can close the case.
