SMB - External Storage (Networkshare) Sync
Hi all, we are using Nextcloud in conjunction with Onlyoffice to open documents that are on a network drive via the Edge browser. The sync. of the documents to the Nextcloud works, but they are not updated after changing the network drive in Onlyoffice. Only when we rename the file it is also updated in Onlyoffice. In Nextcloud they are updated after 5 minutes at the latest. How can I change this so that the documents I open in Onlyoffice are always up to date?
Hope you can follow me and I am looking forward to your suggestions for a solution!
  • Documentserver Container (Portainer)
  • Nextcloud Container (Portainer)
Greetings Marco
Hello @marco
I don’t really understand your set up. Please correct me if I’m wrong - you have an external storage connected to the Nexcloud portal and you are trying to edit documents that are located in that storage?
Please clarify this statement. It’s not clear about “changing the network drive in Onlyoffice”.
Also, are you renaming files that are located in Nextcloud to update them or in the external storage?
Looking forward to your reply.
Hi Konstantin, thanks for your quick reply. I have an external storage connected to the Nextcloud portal (SMB/Cifs). I want to view the documents only in the browser with Onlyoffice.
When I edit/save a document in the external storage and then want to view it in Nextcloud via Onlyoffice, the current version is not displayed. When I open it, I only see the previous version.
Only when I rename it in the external storage, the document is updated in Onlyoffice. The same happens when I disconnect the external storage and reconnect after that the file is up to date in Onlyoffice.
regards Marco
Please provide next information:
  • OS of the host server;
  • Document Server version and installation type (Docker, DEB/RPM, exe);
  • Nextcloud version;
  • version of the connector app;
  • type and version of your external SMB/CIFS storage.
Waiting for your reply.
  • Operating System: Linux 5.10.0-17-amd64 x86_64, On the Portainer its Version 2.14.2
  • Version: 7.1.1-23 Installation type Docker
  • Nextcloud Version 24.0.4
  • Did you mean the External storage support App on the Nextcloud? Version 1.16.1
  • Netapp Storage but it´s the same problem on a Windows-Share (Windows Server 2016)
thx. regards Marco
I can see that you are using an outdated version of Document Server. Please consider updating to the actual version 7.2.2 and checking the issue again.
Not really, but it is also useful information. I meant the ONLYOFFICE connector app for Nextcloud. You can check the version of it in the Apps menu of your Nextcloud portal.
I’m sorry for not being completely clear.
  • What is the fastest way to update the document server?
  • Onlyoffice connector App Version 7.5.8
Since you are using Portainer the easiest way, I do believe this is so, is to stop and remove currently running Document Server container and run a new one with actual version on the same port. Also, if you are using any mounted volumes then make sure to point them too.
I did the update to 7.2.2 but unfortunately no improvement :frowning:
That’s unfortunate.
Please provide a bit more information:
  • where do you exactly renaming files to update them for Document Server? In your storage or in Nextcloud?
  • when you are saving a file in your storage it is updated in Nextcloud after 5-ish minutes, so after that the version loads with the final content in the editors, is that so?
  • is is possible to record a video demonstration of your actions with updating file for Document Server?
Also, please run a small test with the storage - after editing a document in your storage try downloading it to your PC and checking if the recently added content persists in the document. Let me know the results.
  • I rename it in my external storage. In nextcloud the files are up to date when I download them. Is there a cache or something in the document server or is there a command to be able to update the files in the document server?
  • No, after 5 minutens and more nothing happens.
Thanks for providing the information.
We are checking the situation.
the same problem, updates only go in one direction from nextcloud to smb share. Is there any solution?
Hello @a.maltsev
Please specify the storage that you are using.
nextcloud 25.0.5 with smb\cifs external storage on windows server 2019. Onlyoffice server 7.2.2
Thank you for the info.
Note that you are using an outdated version of Document Server. Please update you current instance to the actual version 7.3.3-49 and check the situation again.
Hello all,
the problem is solved. In the default.json there are some parameters which have to be adjusted. Unfortunately, I am no longer sure which ones. Can you please provide me your original default.json so I can compare it with mine?
Thanks in advance! Regards Marco
Hello @marco
Here you can find default.json of the fresh installation of Document Server:
	"statsd": {
		"useMetrics": false,
		"host": "localhost",
		"port": "8125",
		"prefix": "ds."
	"log": {
		"filePath": "",
		"options": {
			"replaceConsole": true
	"queue": {
		"type": "rabbitmq",
		"visibilityTimeout": 300,
		"retentionPeriod": 900
	"storage": {
		"name": "storage-fs",
		"fs": {
			"folderPath": "",
			"urlExpires": 900,
			"secretString": "verysecretstring"
		"region": "",
		"endpoint": "http://localhost/s3",
		"bucketName": "cache",
		"storageFolderName": "files",
		"cacheFolderName": "data",
		"urlExpires": 604800,
		"accessKeyId": "AKID",
		"secretAccessKey": "SECRET",
		"sslEnabled": false,
		"s3ForcePathStyle": true,
		"externalHost": ""
	"rabbitmq": {
		"url": "amqp://guest:guest@localhost:5672",
		"socketOptions": {},
		"exchangepubsub": "ds.pubsub",
		"queueconverttask": "ds.converttask",
		"queueconvertresponse": "ds.convertresponse",
		"exchangeconvertdead": "ds.exchangeconvertdead",
		"queueconvertdead": "ds.convertdead",
		"queuedelayed": "ds.delayed"
	"activemq": {
		"connectOptions": {
			"port": 5672,
			"name": "admin",
			"reconnect": false
		"queueconvertdead": "ActiveMQ.DLQ",
		"queuedelayed": "ds.delayed",
		"topicpubsub": "ds.pubsub"
	"dnscache": {
		"enable" : true,
		"ttl" : 300,
		"cachesize" : 1000
	"openpgpjs": {
		"config": {
		"encrypt": {
			"passwords": ["verysecretstring"]
		"decrypt": {
	"bottleneck": {
		"getChanges": {
	"wopi": {
		"enable": false,
		"host" : "",
		"htmlTemplate" : "../../web-apps/apps/api/wopi",
		"wopiZone" : "external-http",
		"favIconUrlWord" : "/web-apps/apps/documenteditor/main/resources/img/favicon.ico",
		"favIconUrlCell" : "/web-apps/apps/spreadsheeteditor/main/resources/img/favicon.ico",
		"favIconUrlSlide" : "/web-apps/apps/presentationeditor/main/resources/img/favicon.ico",
		"fileInfoBlockList" : ["FileUrl"],
		"pdfView": ["pdf", "djvu", "xps", "oxps"],
		"wordView": ["doc", "dotx", "dotm", "dot", "fodt", "ott", "rtf", "mht", "html", "htm", "xml", "epub", "fb2"],
		"wordEdit": ["docx", "docm", "docxf", "oform", "odt", "txt"],
		"cellView": ["xls", "xlsb", "xltx", "xltm", "xlt", "fods", "ots"],
		"cellEdit": ["xlsx", "xlsm", "ods", "csv"],
		"slideView": ["ppt", "ppsx", "ppsm", "pps", "potx", "potm", "pot", "fodp", "otp"],
		"slideEdit": ["pptx", "pptm", "odp"],
		"publicKey": "BgIAAACkAABSU0ExAAgAAAEAAQD/NVqekFNi8X3p6Bvdlaxm0GGuggW5kKfVEQzPGuOkGVrz6DrOMNR+k7Pq8tONY+1NHgS6Z+v3959em78qclVDuQX77Tkml0xMHAQHN4sAHF9iQJS8gOBUKSVKaHD7Z8YXch6F212YSUSc8QphpDSHWVShU7rcUeLQsd/0pkflh5+um4YKEZhm4Mou3vstp5p12NeffyK1WFZF7q4jB7jclAslYKQsP82YY3DcRwu5Tl/+W0ifVcXze0mI7v1reJ12pKn8ifRiq+0q5oJST3TRSrvmjLg9Gt3ozhVIt2HUi3La7Qh40YOAUXm0g/hUq2BepeOp1C7WSvaOFHXe6Hqq",
		"modulus": "qnro3nUUjvZK1i7UqeOlXmCrVPiDtHlRgIPReAjt2nKL1GG3SBXO6N0aPbiM5rtK0XRPUoLmKu2rYvSJ/Kmkdp14a/3uiEl788VVn0hb/l9OuQtH3HBjmM0/LKRgJQuU3LgHI67uRVZYtSJ/n9fYdZqnLfveLsrgZpgRCoabrp+H5Uem9N+x0OJR3LpToVRZhzSkYQrxnERJmF3bhR5yF8Zn+3BoSiUpVOCAvJRAYl8cAIs3BwQcTEyXJjnt+wW5Q1VyKr+bXp/39+tnugQeTe1jjdPy6rOTftQwzjro81oZpOMazwwR1aeQuQWCrmHQZqyV3Rvo6X3xYlOQnlo1/w==",
		"exponent": "AQAB",
		"privateKey": "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",
		"publicKeyOld": "BgIAAACkAABSU0ExAAgAAAEAAQD/NVqekFNi8X3p6Bvdlaxm0GGuggW5kKfVEQzPGuOkGVrz6DrOMNR+k7Pq8tONY+1NHgS6Z+v3959em78qclVDuQX77Tkml0xMHAQHN4sAHF9iQJS8gOBUKSVKaHD7Z8YXch6F212YSUSc8QphpDSHWVShU7rcUeLQsd/0pkflh5+um4YKEZhm4Mou3vstp5p12NeffyK1WFZF7q4jB7jclAslYKQsP82YY3DcRwu5Tl/+W0ifVcXze0mI7v1reJ12pKn8ifRiq+0q5oJST3TRSrvmjLg9Gt3ozhVIt2HUi3La7Qh40YOAUXm0g/hUq2BepeOp1C7WSvaOFHXe6Hqq",
		"modulusOld": "qnro3nUUjvZK1i7UqeOlXmCrVPiDtHlRgIPReAjt2nKL1GG3SBXO6N0aPbiM5rtK0XRPUoLmKu2rYvSJ/Kmkdp14a/3uiEl788VVn0hb/l9OuQtH3HBjmM0/LKRgJQuU3LgHI67uRVZYtSJ/n9fYdZqnLfveLsrgZpgRCoabrp+H5Uem9N+x0OJR3LpToVRZhzSkYQrxnERJmF3bhR5yF8Zn+3BoSiUpVOCAvJRAYl8cAIs3BwQcTEyXJjnt+wW5Q1VyKr+bXp/39+tnugQeTe1jjdPy6rOTftQwzjro81oZpOMazwwR1aeQuQWCrmHQZqyV3Rvo6X3xYlOQnlo1/w==",
		"exponentOld": "AQAB",
		"privateKeyOld": "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",
		"refreshLockInterval": "10m"
	"tenants": {
		"baseDir": "",
		"baseDomain": "",
		"filenameSecret": "secret.key",
		"filenameLicense": "license.lic",
		"defaultTenant": "localhost",
		"cache" : {
			"stdTTL": 300,
			"checkperiod": 60,
			"useClones": false
	"services": {
		"CoAuthoring": {
			"server": {
				"port": 8000,
				"workerpercpu": 1,
				"mode": "development",
				"limits_tempfile_upload": 104857600,
				"limits_image_size": 26214400,
				"limits_image_download_timeout": {
					"connectionAndInactivity": "2m",
					"wholeCycle": "2m"
				"callbackRequestTimeout": {
					"connectionAndInactivity": "10m",
					"wholeCycle": "10m"
				"healthcheckfilepath": "../public/healthcheck.docx",
				"savetimeoutdelay": 5000,
				"edit_singleton": false,
				"forgottenfiles": "forgotten",
				"forgottenfilesname": "output",
				"maxRequestChanges": 20000,
				"openProtectedFile": true,
				"editorDataStorage": "editorDataMemory",
				"assemblyFormatAsOrigin": true,
				"newFileTemplate" : "../../document-templates/new",
				"downloadFileAllowExt": ["pdf", "xlsx"],
				"tokenRequiredParams": true
			"requestDefaults": {
				"headers": {
					"User-Agent": "Node.js/6.13",
					"Connection": "Keep-Alive"
				"gzip": true,
				"rejectUnauthorized": true
			"autoAssembly": {
				"enable": false,
				"interval": "5m",
				"step": "1m"
			"utils": {
				"utils_common_fontdir": "null",
				"utils_fonts_search_patterns": "*.ttf;*.ttc;*.otf",
				"limits_image_types_upload": "jpg;jpeg;jpe;png;gif;bmp"
			"sql": {
				"type": "postgres",
				"tableChanges": "doc_changes",
				"tableResult": "task_result",
				"dbHost": "localhost",
				"dbPort": 5432,
				"dbName": "onlyoffice",
				"dbUser": "onlyoffice",
				"dbPass": "onlyoffice",
				"charset": "utf8",
				"connectionlimit": 10,
				"max_allowed_packet": 1048575,
				"pgPoolExtraOptions": {}
			"redis": {
				"name": "redis",
				"prefix": "ds:",
				"port": 6379,
				"options": {}
			"pubsub": {
				"maxChanges": 1000
			"expire": {
				"saveLock": 60,
				"presence": 300,
				"locks": 604800,
				"changeindex": 86400,
				"lockDoc": 30,
				"message": 86400,
				"lastsave": 604800,
				"forcesave": 604800,
				"saved": 3600,
				"documentsCron": "0 */2 * * * *",
				"files": 86400,
				"filesCron": "00 00 */1 * * *",
				"filesremovedatonce": 100,
				"sessionidle": "1h",
				"sessionabsolute": "30d",
				"sessionclosecommand": "2m",
				"pemStdTTL": "1h",
				"pemCheckPeriod": "10m",
				"updateVersionStatus": "5m",
				"monthUniqueUsers": "1y"
			"ipfilter": {
				"rules": [{"address": "*", "allowed": true}],
				"useforrequest": false,
				"errorcode": 403
			"request-filtering-agent" : {
				"allowPrivateIPAddress": true,
				"allowMetaIPAddress": true
			"secret": {
				"browser": {"string": "secret", "file": ""},
				"inbox": {"string": "secret", "file": ""},
				"outbox": {"string": "secret", "file": ""},
				"session": {"string": "secret", "file": ""}
			"token": {
				"enable": {
					"browser": false,
					"request": {
						"inbox": false,
						"outbox": false
				"browser": {
					"secretFromInbox": true
				"inbox": {
					"header": "Authorization",
					"prefix": "Bearer ",
					"inBody": false
				"outbox": {
					"algorithm": "HS256",
					"expires": "5m",
					"inBody": false,
					"urlExclusionRegex": ""
				"session": {
					"expires": "30d"
				"verifyOptions": {
					"clockTolerance": 60
			"plugins": {
				"uri": "/sdkjs-plugins",
				"autostart": []
			"themes": {
				"uri": "/web-apps/apps/common/main/resources/themes"
			"editor":{
				"spellcheckerUrl": "",
				"reconnection":{
					"attempts": 50,
					"delay": "2s"
				"binaryChanges": false,
				"websocketMaxPayloadSize": "1.5MB",
				"maxChangesSize": "0mb"
			"sockjs": {
				"sockjs_url": "",
				"disable_cors": true,
				"websocket": true
			"socketio": {
				"connection": {
					"path": "/doc/",
					"serveClient": false,
					"pingTimeout": 20000,
					"pingInterval": 25000,
					"maxHttpBufferSize": 1e8
			"callbackBackoffOptions": {
				"retries": 0,
				"timeout":{
					"factor": 2,
					"minTimeout": 1000,
					"maxTimeout": 2147483647,
					"randomize": false
				"httpStatus": "429,500-599"
	"license" : {
		"license_file": "",
		"warning_limit_percents": 70,
		"packageType": 0
	"FileConverter": {
		"converter": {
			"maxDownloadBytes": 104857600,
			"downloadTimeout": {
				"wholeCycle": "2m"
			"downloadAttemptMaxCount": 3,
			"downloadAttemptDelay": 1000,
			"maxprocesscount": 1,
			"fontDir": "null",
			"presentationThemesDir": "null",
			"x2tPath": "null",
			"docbuilderPath": "null",
			"args": "",
			"spawnOptions": {},
			"errorfiles": "",
			"streamWriterBufferSize": 8388608,
			"maxRedeliveredCount": 2,
			"inputLimits": [
				"type": "docx;dotx;docm;dotm",
				"zip": {
					"uncompressed": "50MB",
					"template": "*.xml"
				"type": "xlsx;xltx;xlsm;xltm",
				"zip": {
					"uncompressed": "300MB",
					"template": "*.xml"
				"type": "pptx;ppsx;potx;pptm;ppsm;potm",
				"zip": {
					"template": "*.xml"
“statsd”: {
“useMetrics”: false,
“host”: “localhost”,
“port”: “8125”,
“prefix”: “ds.”
“log”: {
“filePath”: “”,
“options”: {
“replaceConsole”: true
“queue”: {
“type”: “rabbitmq”,
“visibilityTimeout”: 300,
“retentionPeriod”: 900
“storage”: {
“name”: “storage-fs”,
“fs”: {
“folderPath”: “”,
“urlExpires”: 900,
“secretString”: “verysecretstring”
“region”: “”,
“endpoint”: “http://localhost/s3”,
“bucketName”: “cache”,
“storageFolderName”: “files”,
“cacheFolderName”: “data”,
“urlExpires”: 604800,
“accessKeyId”: “AKID”,
“secretAccessKey”: “SECRET”,
“sslEnabled”: false,
“s3ForcePathStyle”: true,
“externalHost”: “”
“rabbitmq”: {
“url”: “amqp://guest:guest@localhost:5672”,
“socketOptions”: {},
“exchangepubsub”: “ds.pubsub”,
“queueconverttask”: “ds.converttask”,
“queueconvertresponse”: “ds.convertresponse”,
“exchangeconvertdead”: “ds.exchangeconvertdead”,
“queueconvertdead”: “ds.convertdead”,
“queuedelayed”: “ds.delayed”
“activemq”: {
“connectOptions”: {
“port”: 5672,
“name”: “admin”,
“reconnect”: false
“queueconvertdead”: “ActiveMQ.DLQ”,
“queuedelayed”: “ds.delayed”,
“topicpubsub”: “ds.pubsub”
“dnscache”: {
“enable” : true,
“ttl” : 300,
“cachesize” : 1000
“openpgpjs”: {
“config”: {
“encrypt”: {
“passwords”: [“verysecretstring”]
“decrypt”: {
“bottleneck”: {
“getChanges”: {
“wopi”: {
“enable”: false,
“host” : “”,
“htmlTemplate” : “…/…/web-apps/apps/api/wopi”,
“wopiZone” : “external-http”,
“favIconUrlWord” : “/web-apps/apps/documenteditor/main/resources/img/favicon.ico”,
“favIconUrlCell” : “/web-apps/apps/spreadsheeteditor/main/resources/img/favicon.ico”,
“favIconUrlSlide” : “/web-apps/apps/presentationeditor/main/resources/img/favicon.ico”,
“fileInfoBlockList” : [“FileUrl”],
“pdfView”: [“pdf”, “djvu”, “xps”, “oxps”],
“wordView”: [“doc”, “dotx”, “dotm”, “dot”, “fodt”, “ott”, “rtf”, “mht”, “html”, “htm”, “xml”, “epub”, “fb2”],
“wordEdit”: [“docx”, “docm”, “docxf”, “oform”, “odt”, “txt”],
“cellView”: [“xls”, “xlsb”, “xltx”, “xltm”, “xlt”, “fods”, “ots”],
“cellEdit”: [“xlsx”, “xlsm”, “ods”, “csv”],
“slideView”: [“ppt”, “ppsx”, “ppsm”, “pps”, “potx”, “potm”, “pot”, “fodp”, “otp”],
“slideEdit”: [“pptx”, “pptm”, “odp”],
“publicKey”: "BgIAAACkAABSU0ExAAgAAAEAAQD/NVqekFNi8X3p6Bvdlaxm0GGuggW5kKfVEQzPGuOkGVrz6DrOMNR+k7Pq8tONY+1NHgS6Z+v3959em78qclVDuQX77Tkml0xMHAQHN4sAHF9iQJS8gOBUKSVKaHD7Z8YXch6F212YSUSc8QphpDSHWVSh>
“modulus”: "qnro3nUUjvZK1i7UqeOlXmCrVPiDtHlRgIPReAjt2nKL1GG3SBXO6N0aPbiM5rtK0XRPUoLmKu2rYvSJ/Kmkdp14a/3uiEl788VVn0hb/l9OuQtH3HBjmM0/LKRgJQuU3LgHI67uRVZYtSJ/n9fYdZqnLfveLsrgZpgRCoabrp+H5Uem9N+x0O>
“exponent”: “AQAB”,
“privateKey”: "MIIEowIBAAKCAQEAqnro3nUUjvZK1i7UqeOlXmCrVPiDtHlRgIPReAjt2nKL1GG3SBXO6N0aPbiM5rtK0XRPUoLmKu2rYvSJ/Kmkdp14a/3uiEl788VVn0hb/l9OuQtH3HBjmM0/LKRgJQuU3LgHI67uRVZYtSJ/n9fYdZqnLfveLsrgZpg>
“publicKeyOld”: "BgIAAACkAABSU0ExAAgAAAEAAQD/NVqekFNi8X3p6Bvdlaxm0GGuggW5kKfVEQzPGuOkGVrz6DrOMNR+k7Pq8tONY+1NHgS6Z+v3959em78qclVDuQX77Tkml0xMHAQHN4sAHF9iQJS8gOBUKSVKaHD7Z8YXch6F212YSUSc8QphpDSHW>
“modulusOld”: "qnro3nUUjvZK1i7UqeOlXmCrVPiDtHlRgIPReAjt2nKL1GG3SBXO6N0aPbiM5rtK0XRPUoLmKu2rYvSJ/Kmkdp14a/3uiEl788VVn0hb/l9OuQtH3HBjmM0/LKRgJQuU3LgHI67uRVZYtSJ/n9fYdZqnLfveLsrgZpgRCoabrp+H5Uem9N+>
“exponentOld”: “AQAB”,
“privateKeyOld”: "MIIEowIBAAKCAQEAqnro3nUUjvZK1i7UqeOlXmCrVPiDtHlRgIPReAjt2nKL1GG3SBXO6N0aPbiM5rtK0XRPUoLmKu2rYvSJ/Kmkdp14a/3uiEl788VVn0hb/l9OuQtH3HBjmM0/LKRgJQuU3LgHI67uRVZYtSJ/n9fYdZqnLfveLsrg>
“refreshLockInterval”: “10m”
“tenants”: {
“baseDir”: “”,
“baseDomain”: “”,
“filenameSecret”: “secret.key”,
“filenameLicense”: “license.lic”,
“defaultTenant”: “localhost”,
“cache” : {
“stdTTL”: 300,
“checkperiod”: 60,
“useClones”: false
“services”: {
“CoAuthoring”: {
“server”: {
“port”: 8000,
“workerpercpu”: 1,
“mode”: “development”,
“limits_tempfile_upload”: 104857600,
“limits_image_size”: 26214400,
“limits_image_download_timeout”: {
“connectionAndInactivity”: “2m”,
“wholeCycle”: “2m”
“callbackRequestTimeout”: {
“connectionAndInactivity”: “10m”,
“wholeCycle”: “10m”
“healthcheckfilepath”: “…/public/healthcheck.docx”,
“savetimeoutdelay”: 5000,
“edit_singleton”: false,
“forgottenfiles”: “forgotten”,
“forgottenfilesname”: “output”,
“maxRequestChanges”: 20000,
“openProtectedFile”: true,
“editorDataStorage”: “editorDataMemory”,
“assemblyFormatAsOrigin”: true,
“newFileTemplate” : “…/…/document-templates/new”,
“downloadFileAllowExt”: [“pdf”, “xlsx”],
“tokenRequiredParams”: true
“requestDefaults”: {
“headers”: {
“User-Agent”: “Node.js/6.13”,
“Connection”: “Keep-Alive”
“gzip”: true,
“rejectUnauthorized”: true
“autoAssembly”: {
“enable”: false,
“interval”: “5m”,
“step”: “1m”
“utils”: {
“utils_common_fontdir”: “null”,
“utils_fonts_search_patterns”: “.ttf;.ttc;*.otf”,
“limits_image_types_upload”: “jpg;jpeg;jpe;png;gif;bmp”
“sql”: {
“type”: “postgres”,
“tableChanges”: “doc_changes”,
“tableResult”: “task_result”,
“dbHost”: “localhost”,
“dbPort”: 5432,
“dbName”: “onlyoffice”,
“dbUser”: “onlyoffice”,
“dbPass”: “onlyoffice”,
“charset”: “utf8”,
“connectionlimit”: 10,
“max_allowed_packet”: 1048575,
“pgPoolExtraOptions”: {}
“redis”: {
“name”: “redis”,
“prefix”: “ds:”,
“port”: 6379,
“options”: {}
“pubsub”: {
“maxChanges”: 1000
“expire”: {
“saveLock”: 60,
“presence”: 300,
“locks”: 604800,
“changeindex”: 86400,
“lockDoc”: 30,
“message”: 86400,
“lastsave”: 604800,
“forcesave”: 604800,
“saved”: 3600,
“documentsCron”: “0 /2 * * * ",
“files”: 86400,
“filesCron”: “00 00 /1 * * ",
“filesremovedatonce”: 100,
“sessionidle”: “1h”,
“sessionabsolute”: “30d”,
“sessionclosecommand”: “2m”,
“pemStdTTL”: “1h”,
“pemCheckPeriod”: “10m”,
“updateVersionStatus”: “5m”,
“monthUniqueUsers”: “1y”
“ipfilter”: {
“rules”: [{“address”: "
", “allowed”: true}],
“useforrequest”: false,
“errorcode”: 403
“request-filtering-agent” : {
“allowPrivateIPAddress”: true,
“allowMetaIPAddress”: true
“secret”: {
“browser”: {“string”: “secret”, “file”: “”},
“inbox”: {“string”: “secret”, “file”: “”},
“outbox”: {“string”: “secret”, “file”: “”},
“session”: {“string”: “secret”, “file”: “”}
“token”: {
“enable”: {
“browser”: false,
“request”: {
“inbox”: false,
“outbox”: false
“browser”: {
“secretFromInbox”: true
“inbox”: {
“header”: “Authorization”,
“prefix”: "Bearer ",
“inBody”: false
“outbox”: {
“algorithm”: “HS256”,
“expires”: “5m”,
“inBody”: false,
“urlExclusionRegex”: “”
“session”: {
“expires”: “30d”
“verifyOptions”: {
“clockTolerance”: 60
“plugins”: {
“uri”: “/sdkjs-plugins”,
“autostart”: []
“themes”: {
“uri”: “/web-apps/apps/common/main/resources/themes”
“editor”:{
“spellcheckerUrl”: “”,
“reconnection”:{
“attempts”: 50,
“delay”: “2s”
“binaryChanges”: false,
“websocketMaxPayloadSize”: “1.5MB”,
“maxChangesSize”: “0mb”
“sockjs”: {
“sockjs_url”: “”,
“disable_cors”: true,
“websocket”: true
“socketio”: {
“connection”: {
“path”: “/doc/”,
“serveClient”: false,
“pingTimeout”: 20000,
“pingInterval”: 25000,
“maxHttpBufferSize”: 1e8
“callbackBackoffOptions”: {
“retries”: 0,
“timeout”:{
“factor”: 2,
“minTimeout”: 1000,
“maxTimeout”: 2147483647,
“randomize”: false
“httpStatus”: “429,500-599”
“license” : {
“license_file”: “”,
“warning_limit_percents”: 70,
“packageType”: 0
“FileConverter”: {
“converter”: {
“maxDownloadBytes”: 104857600,
“downloadTimeout”: {
“wholeCycle”: “2m”
“downloadAttemptMaxCount”: 3,
“downloadAttemptDelay”: 1000,
“maxprocesscount”: 1,
“fontDir”: “null”,
“presentationThemesDir”: “null”,
“x2tPath”: “null”,
“docbuilderPath”: “null”,
“args”: “”,
“spawnOptions”: {},
“errorfiles”: “”,
“streamWriterBufferSize”: 8388608,
“maxRedeliveredCount”: 2,
“inputLimits”: [
“type”: “docx;dotx;docm;dotm”,
“zip”: {
“uncompressed”: “50MB”,
“template”: "
.xml”
“type”: “xlsx;xltx;xlsm;xltm”,
“zip”: {
“uncompressed”: “300MB”,
“template”: "
.xml"
“type”: “pptx;ppsx;potx;pptm;ppsm;potm”,
“zip”: {
“template”: "
.xml”
Hello, the following has been changed. Please make a copy of the default.json before, in case of problems.
“lastsave”: 10,
“forcesave”: 10,
“saved”: 10,
“documentsCron”: " * * * * * *",
“files”: 10,
“filesCron”: " * * * * *",
Here I am not sure: Delete this:
“socketio”: {
“connection”: {
“path”: “/doc/”,
Hope it helps! Regards Marco
