Option for dark background in Presentation
It would be better to add an option for dark background in Presentation. I have named the screenshot “dark background”, and I have written the same name in screenshot, so that You know where should the dark background apply.
Thanks
Hi @nicesto
We are working on your suggestion.
Please clarify the following information:
  • The model of your phone.
  • Are you using a mobile application connected to OnlyOffice cloud?
a. Huawei P9 Lite; Model:VNS-L21
b. I’m not using a mobile app connected to the onlyoffice cloud.
Hello @nicesto
We have registered your suggestion to add an option for dark background in Presentation (android) under the number 62236.
Thank you for contributing to our product. We will try to add this feature in the next versions.
