I try to edit docx file from odoo 16.0-20230705 (Community) by onlyoffice_odoo-16.0.1.0 and … Error
Document Server version: 7.3.3.49
Connector version: 16.0.1.0
DMS (platform) version: odoo 16.0-20230705 (Community)
OS: Debian 11.7 (odoo), Windows Server 2019 Standard (onlyoffice)
Browser version: Microsoft Edge 114.0.1823.58
Attach logs if possible.
500: Internal Server Error
(http://192.168.1.249:8069/onlyoffice/editor/966#error_traceback)
Traceback (most recent call last): File “/usr/lib/python3/dist-packages/odoo/http.py”, line 1584, in _serve_db return service_model.retrying(self._serve_ir_http, self.env) File “/usr/lib/python3/dist-packages/odoo/service/model.py”, line 133, in retrying result = func() File “/usr/lib/python3/dist-packages/odoo/http.py”, line 1611, in _serve_ir_http response = self.dispatcher.dispatch(rule.endpoint, args) File “/usr/lib/python3/dist-packages/odoo/http.py”, line 1725, in dispatch return self.request.registry[‘ir.http’]._dispatch(endpoint) File “/usr/lib/python3/dist-packages/odoo/addons/website/models/ir_http.py”, line 235, in _dispatch response = super()._dispatch(endpoint) File “/usr/lib/python3/dist-packages/odoo/addons/base/models/ir_http.py”, line 154, in _dispatch result = endpoint(**request.params) File “/usr/lib/python3/dist-packages/odoo/http.py”, line 697, in route_wrapper result = endpoint(self, *args, **params_ok) File “/usr/lib/python3/dist-packages/odoo/addons/onlyoffice_odoo/controllers/controllers.py”, line 87, in render_editor return request.render(“onlyoffice_odoo.onlyoffice_editor”, self.prepare_editor_values(attachment, access_token)) File “/usr/lib/python3/dist-packages/odoo/addons/onlyoffice_odoo/controllers/controllers.py”, line 150, in prepare_editor_values path_part = str(data[“id”]) + “?oo_security_token=” + security_token + (“&access_token=” +access_token if access_token else “”) TypeError: can only concatenate str (not “bytes”) to str
