Document Server version: 7.4.1-36
OS: exe Windows
Browser version: Wersja 117.0.5938.92 (Oficjalna wersja) (64-bitowa)
Hi
I try to run example but it dosn’t work. I get error. Where is the problem? This is a standard installation.
Buttons are without graphics. I try to create new document and load existing document. But result is the same. How to fix the problem? Mayby my configuration is wrong. Openoffice installation was correct.
I see that you have submitted several posts on the same issue. I’d kindly ask you to avoid creating duplicate posts that are related to the same topic.
I replied to you in the original thread, please see it:
