Seconded. I am not a fan of the default margins and find it to be a slight annoyance that I have to switch them to 1-inch every time I make a document.
You can locate the empty files (new.docx/new.xlsx/new.pptx) for every locale at
/opt/onlyoffice/desktopeditors/converter/empty
C:\Program Files\ONLYOFFICE\DesktopEditors\converter\empty
and set your own settings for the default files.
Thanks for the response. I made a few docs with the settings I want and just open those first, but if it’s of any help to you, I did see Carl’s post, but I don’t have that path. /opt does not have an only office folder. I am using mint 21.3 and OnlyOffice is installed. But as I said the workaround is fine. I really do love the whole interface and functionality of Open Office!!!
In this post you mentioned that OnlyOffice is working on Slide Master feature, but I still can’t find a way to change fonts in the slides easily. Coould you post an update on the status of
Dear @Kees
I have to say ‘sorry’ a hundred times and it still wouldn’t be enough.
Sorry for the late reply. We try to solve any request in a timely manner. However, sometimes the response time can be long due to high volume of requests.
I have seen your another (the same) post: Permanently change default font - #13 by Alexandre
and have already answered it.
P.S. Please do not post the same request in different topics.
P.P.S. If you prefer personal assistance, please contact colleagues of mine from Sales team: Get dedicated support
Empty documents with Flatpak in Linux are located at
/var/lib/flatpak/app/org.onlyoffice.desktopeditors/x86_64/stable/**/files/bin/opt/onlyoffice/desktopeditors/converter/empty
We can already create styles in a single document. How hard is it to tweak the program to allow saving a style to the default Styles selector? That way we can use it across documents.
Hello @Jared
We already thought about saving custom style and using it across different documents, and we are working on it already. Unfortunately, there’s no ETA at the moment. I will contact you once the feature is released.
