I have been struggling to get lists to render correctly when generating an .oform file from a .docxf in Docs. Though the spacing is as desired in the .docxf file (with a tab indent between the number and the text), the .oform always saves with the first line indented by only a space. Any insight into how to rectify this would be greatly appreciated!
I posted on the onlyoffice subreddit too - https://www.reddit.com/r/OnlyOffice/comments/18l9xbu/list_formatting_difficulties/
Hi @No_Season_5288
Can I ask you to attach 2 files to your response?
(oform + docxf )
Certainly, no problem at all! Attached are both file types.
Ah correction - here are LINKS, as new forum users cannot upload files to posts:
Live Performance Contract (2).docfx
Live Performance Contract (2).oform
Hello!
I think this is the same bug - Bullet list indentation bug
Hi guys!
@Alfozavr
Yes, you are correct! This issue will be resolved in the upcoming version 8.0. ( I won’t be able to specify exact dates, but approximately - January to February)
@No_Season_5288
Thank you for files
Hi Nikolas and Alfozavr,
My pleasure to share the files and work with y’all to get to the bottom of this! As Alfozavr has also noted, I am realizing that I am experiencing this issue in regular .docx files as well (though it is not as consistently reproducible).
That said, I have also encountered additional buggy behavior when saving .oforms to pdf - can I post about those here or would it be better to start another thread?
@No_Season_5288
Certainly, it would be more convenient if you create a new topic.
Thank you
Will do! Going to reach out to you now directly.
