Do you want to: Suggest a feature / Report a bug / Ask a how-to question: BUG
For feature suggestions, describe the result you would like to achieve in detail.: I DONT WANT THE PROGRAM TO SCROLL BACK UP WHEN I EDIT ABOVE THE FREEZE FRAME
Document Server version: VIDEO ATTACHED
Type of installation of the Document Server (docker, deb/rpm, exe, please point us to the installation guide that you used as well): EXE
OS: WINDOWS 10 PRO
Browser version:
Additional information:
Steps to reproduce.
- Below the freeze frame, scroll down as much as you want.
- Using the mouse click a cell
- Using the keyboard write any cell above the freeze frame.
4, Notice that below the freeze frame, it will not show where you left before, instead it will go back to the top of non-freezed the frame
Frame.xlsx (30.2 KB)
