I am experiencing issues with document processing on my ONLYOFFICE installation using Docker. After following the installation guide, I encountered errors related to document changes and version updates, specifically:
Update Version error
changesError: Error in the sdk-all.js file
Server Specifications:
CPU: 6 cores
RAM: 24 GB
Storage: 230 GB NVMe
Bandwidth: 250 Mb/s
OS: Ubuntu
Browser: Google Chrome (latest version)
These issues affect our ability to edit and save documents, which is critical for our operations. I would appreciate any insights or solutions from the community regarding these errors.
Can you share more info from logs? This part even though provides some info, but not quite enough. You can also try removing container with Document Server and running the script with flag -u true to reinstall it, of course, if you are sure that problem comes from it.
