I have a document file, and I’ve made a table in it.
I want in one of the table’s columns to fill the empty space between the text and the end of the cell with dots on it own every time.
Is this possible? If yes, how do I do that?
I can do that in normal text with adding a dot leader and pressing tab after the text and it will fill with dots, but in a table when I press tab it goes to the next cell instead.
If you don’t mind I will join this thread as well. @Yassine is right, there’s tabulation limitation for tables in docx file, we have discussed it in another thread:
Will the search and replace meet your scenario @testgcd ? (replacing ^p and ^w with . )
