One outstanding feature that has made my life easier, unfortunately, that keeps me using something like MS PowerPoint, is the possibility to make a right-click on one image on the slide, and be able to replace it with another image I have in the clipboard. That has improved considerably my workflow, in particular when I have to work with many figures from different sources during the day (statistical plots from different programs, etc). Similarly, being able to drag and drop, or copy/paste, slides from the thumbnails between presentation files has helped my workflow considerably. Are there any plans to include these features in future versions? Thanks for reading this!
Hello @Rollerpunk
We discussed similar request in this thread: Unable to copy slides from a Powerpoint into a cloud OnlyOffice presentation
Please confirm that you are looking for the ability to copy slide from another editor (MS Powerpoint) and paste it into ONLYOFFICE.
Hi. I read thread and there is a caveat. I could understand you cannot import slides from the thumbnails when open one file in MS PowerPoint and the other one in onlyoffice. However, it should be possible if both files are opened on the same program. Just drag and drop would increase productivity a lot.
Understood, we are checking the situation. I will contact you as soon as possible.
Dear @Rollerpunk
We have added your suggestion (implement drag-n-drop copying slides between presentations) to internal tracksystem. We have started working on it.
One more thing. Currently, there’s a workaround solution, you can copy the slide using ‘keep source formatting’. Here’s a video sample for your reference:
