Version of Plone:
Version of onlyoffice connector:
Plone full instance log from save the onlyoffice setup to create a new presentation.pptx
/backend/instance/var/log# cat instance.log
2024-05-14 11:14:03,303 WARNING [waitress.queue:114][MainThread] Task queue depth is 1
2024-05-14 11:14:08,165 INFO [plone.protect:32][waitress-1] auto rotating keyring _forms
2024-05-14 11:14:08,165 INFO [plone.protect:32][waitress-1] auto rotating keyring _anon
2024-05-14 11:14:08,166 INFO [plone.protect:32][waitress-1] auto rotating keyring _anon
2024-05-14 11:18:49,850 ERROR [onlyoffice:217][waitress-1] SAdfasdf
2024-05-14 11:19:05,747 INFO [onlyoffice:138][waitress-3] getting config for http://10.83.64.67:8080/test/presentation.pptx
2024-05-14 11:19:06,917 INFO [onlyoffice:55][waitress-0] got callback request for http://10.83.64.67:8080/test/presentation.pptx
2024-05-14 11:19:06,928 INFO [onlyoffice:104][waitress-2] got download request for http://10.83.64.67:8080/test/presentation.pptx
2024-05-14 11:19:06,928 ERROR [Zope.SiteErrorLog:36][waitress-2] Exception: http://10.83.64.67:8080/test/presentation.pptx/onlyoffice-dl/file
Traceback (innermost last):
Module ZPublisher.WSGIPublisher, line 181, in transaction_pubevents
Module ZPublisher.WSGIPublisher, line 391, in publish_module
Module ZPublisher.WSGIPublisher, line 285, in publish
Module ZPublisher.mapply, line 98, in mapply
Module ZPublisher.WSGIPublisher, line 68, in call_object
Module plone.namedfile.browser, line 97, in __call__
Module onlyoffice.plone.browser.api, line 110, in _getFile
Exception: Expected JWT
2024-05-14 11:19:07,934 INFO [onlyoffice:104][waitress-1] got download request for http://10.83.64.67:8080/test/presentation.pptx
2024-05-14 11:19:07,935 ERROR [Zope.SiteErrorLog:36][waitress-1] Exception: http://10.83.64.67:8080/test/presentation.pptx/onlyoffice-dl/file
2024-05-14 11:19:08,942 INFO [onlyoffice:104][waitress-3] got download request for http://10.83.64.67:8080/test/presentation.pptx
2024-05-14 11:19:08,942 ERROR [Zope.SiteErrorLog:36][waitress-3] Exception: http://10.83.64.67:8080/test/presentation.pptx/onlyoffice-dl/file
In the meantime Onlyoffice Log (ignoring the difference in time/time zone Settings) :
cat /var/log/onlyoffice/documentserver/converter/out.log
[2024-05-14T00:00:22.829] [WARN] [localhost] [docId] [userId] nodeJS - num of CPUs: 6; availableParallelism: undefined
[2024-05-14T00:00:22.830] [WARN] [localhost] [docId] [userId] nodeJS - update cluster with 1 workers
[2024-05-14T00:00:22.835] [WARN] [localhost] [docId] [userId] nodeJS - worker 474180 started.
[2024-05-14T00:00:22.836] [WARN] [localhost] [docId] [userId] nodeJS - num of CPUs: 6; availableParallelism: undefined
[2024-05-14T00:00:22.837] [WARN] [localhost] [docId] [userId] nodeJS - update cluster with 1 workers
[2024-05-14T03:19:06.826] [ERROR] [localhost] [cHJlc2VudGF0aW9uLnBwdHhfMjAyNC8wNS8xNCAxMToxOTo1LjYzODE0MyBVUy9DZW50cmFs] [admin] nodeJS - error downloadFile:url=http://10.83.64.67:8080/test/presentation.pptx/onlyoffice-dl/file?token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJrZXkiOiJwcmVzZW50YXRpb24ucHB0eCJ9.XqEmteI0bFHfVmZOwu27IVsnfw2QgU3JM93k0ihmDpg;attempt=1;code:null;connect:null Error: Error response: statusCode:500; headers:{"content-length":"27","content-type":"application/json","date":"Tue, 14 May 2024 03:19:06 GMT","server":"waitress","via":"waitress","x-frame-options":"SAMEORIGIN","x-powered-by":"Zope (www.zope.dev), Python (www.python.org)"};
at Request.fResponse (/snapshot/server/Common/sources/utils.js)
at Request.emit (node:events:527:28)
at Request.onRequestResponse (/snapshot/server/Common/node_modules/request/request.js:1066:10)
at ClientRequest.emit (node:events:527:28)
at HTTPParser.parserOnIncomingClient [as onIncoming] (node:_http_client:631:27)
at HTTPParser.parserOnHeadersComplete (node:_http_common:128:17)
at Socket.socketOnData (node:_http_client:494:22)
at Socket.emit (node:events:527:28)
at addChunk (node:internal/streams/readable:315:12)
at readableAddChunk (node:internal/streams/readable:289:9)
at Socket.Readable.push (node:internal/streams/readable:228:10)
at TCP.onStreamRead (node:internal/stream_base_commons:190:23)
[2024-05-14T03:19:07.832] [ERROR] [localhost] [cHJlc2VudGF0aW9uLnBwdHhfMjAyNC8wNS8xNCAxMToxOTo1LjYzODE0MyBVUy9DZW50cmFs] [admin] nodeJS - error downloadFile:url=http://10.83.64.67:8080/test/presentation.pptx/onlyoffice-dl/file?token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJrZXkiOiJwcmVzZW50YXRpb24ucHB0eCJ9.XqEmteI0bFHfVmZOwu27IVsnfw2QgU3JM93k0ihmDpg;attempt=2;code:null;connect:null Error: Error response: statusCode:500; headers:{"content-length":"27","content-type":"application/json","date":"Tue, 14 May 2024 03:19:07 GMT","server":"waitress","via":"waitress","x-frame-options":"SAMEORIGIN","x-powered-by":"Zope (www.zope.dev), Python (www.python.org)"};
[2024-05-14T03:19:08.840] [ERROR] [localhost] [cHJlc2VudGF0aW9uLnBwdHhfMjAyNC8wNS8xNCAxMToxOTo1LjYzODE0MyBVUy9DZW50cmFs] [admin] nodeJS - error downloadFile:url=http://10.83.64.67:8080/test/presentation.pptx/onlyoffice-dl/file?token=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJrZXkiOiJwcmVzZW50YXRpb24ucHB0eCJ9.XqEmteI0bFHfVmZOwu27IVsnfw2QgU3JM93k0ihmDpg;attempt=3;code:null;connect:null Error: Error response: statusCode:500; headers:{"content-length":"27","content-type":"application/json","date":"Tue, 14 May 2024 03:19:08 GMT","server":"waitress","via":"waitress","x-frame-options":"SAMEORIGIN","x-powered-by":"Zope (www.zope.dev), Python (www.python.org)"};
at HTTPParser.parserOnIncomingClient (node:_http_client:631:27)
No other new logs.
