The issue i am having with caldav sounds similar to this one CalDAV calender log in issue - #2 by Alexandre
I attempt to log in using iphone and also have tried browser login and all i get is verification failures. Its possible my syntax is wrong with logging in but I have tried everything i can think of in that department. So I am now asking for help from the forum. I am running community server12.6.0.1900
any help would be greatly appreciated
turns out the issue was that i had the option custom domain name enabled. problem solved
