Footnotes are still disappearing in v.8.3.1.25 (flatpak)
Hi! :slightly_smiling_face:
This issue has been reported before and declared solved via update in:
and in
The last one does not seem to be closed but still I can’t seem to be able to reply, so I am opening this topic.
Even after the last update, the problem presists. The symptoms and mechanism are the same as described by other users in the posts above. I am running the latest version in flatpak (8.3.1.25) under Zorin OS 17.2 Core.
Thanks for caring!
Hello @daniel.k,
We will look into this, thank you for sharing!
Yes, we confirm that the bug is present on the latest version, we will be working on fixing it
Great! You guys are awesome. Thank you. :grinning:
Hi there. In february I got this message: Footnotes dissapear January 2025. OO Up to date. Loosing hours on this while under deadline - #12 by DmitriiV. But by June 8 the issue is still there. Will it be solved? Otherwise I might have to drop Only Office as I am layouting a newspaper with tons of Footnotes.
The 9.0 version hasn’t been released yet, please wait and check
