Feature request - Macro recorder
Hi
In OO, the macro module is stern and you must go through the documentation to find a way to do things.
In MSO, there is a killer feature : the macro recorder.
You start it and the you do anything you want in your file (add content, change colours, even save it), everything is recorded a macro.
Then, you just have to read the code, copy/paste/adapt it to get what you want.
It allows you to save a hugeeee amount of time when it comes to use macros.
Could it be possible to add it in OO ?
Thanks !
Hi @arcqus
That is a good idea. :+1:
We have registered an enhancement suggestion.
Thank you for your suggestion. :handshake:
Unfortunately, I cannot provide any timeframe for implementing this improvement. This is a rather time-consuming innovation.
