Docspace backup hung
Hi, just updated to docspace 3.0.1 (it went well), but when I tried to do an on demand backup to my Backup Room as I had been doing the backup seems to be hung.
Running.
table /onlyoffice-router\tonlyoffice/docspace-router:3.0.1.1
table /onlyoffice-login\tonlyoffice/docspace-login:3.0.1.1
table /onlyoffice-doceditor\tonlyoffice/docspace-doceditor:3.0.1.1
table /onlyoffice-backup\tonlyoffice/docspace-backup:3.0.1.1
table /onlyoffice-studio\tonlyoffice/docspace-studio:3.0.1.1
table /onlyoffice-backup-background-tasks\tonlyoffice/docspace-backup-background:3.0.1.1
table /onlyoffice-files\tonlyoffice/docspace-files:3.0.1.1
table /onlyoffice-files-services\tonlyoffice/docspace-files-services:3.0.1.1
table /onlyoffice-people-server\tonlyoffice/docspace-people-server:3.0.1.1
table /onlyoffice-ssoauth\tonlyoffice/docspace-ssoauth:3.0.1.1
table /onlyoffice-clear-events\tonlyoffice/docspace-clear-events:3.0.1.1
table /onlyoffice-notify\tonlyoffice/docspace-notify:3.0.1.1
table /onlyoffice-api-system\tonlyoffice/docspace-api-system:3.0.1.1
table /onlyoffice-api\tonlyoffice/docspace-api:3.0.1.1
table /onlyoffice-studio-notify\tonlyoffice/docspace-studio-notify:3.0.1.1
table /onlyoffice-socket\tonlyoffice/docspace-socket:3.0.1.1
table /onlyoffice-proxy\tnginx:latest
table /onlyoffice-healthchecks\tonlyoffice/docspace-healthchecks:3.0.1.1
table /onlyoffice-identity-authorization\tonlyoffice/docspace-identity-authorization:3.0.1.1
table /onlyoffice-identity-api\tonlyoffice/docspace-identity-api:3.0.1.1
table /onlyoffice-document-server\tonlyoffice/documentserver:8.3.0.1
table /onlyoffice-rabbitmq\trabbitmq:3.13.6
table /onlyoffice-redis\tredis:7
table /onlyoffice-mysql-server\tmysql:8.3.0
table /onlyoffice-opensearch-dashboards\topensearchproject/opensearch-dashboards:2.11.1
table /onlyoffice-opensearch\tonlyoffice/opensearch:2.11.1
table /onlyoffice-fluent-bit\tfluent/fluent-bit:3.0.2
And I see errors here /var/lib/docker/volumes/onlyoffice_log_data/_data/ASC.Data.Backup.BackgroundTasks.log
at ASC.EventBus.RabbitMQ.DefaultRabbitMQPersistentConnection.<TryConnectAsync>b__10_2() in /app/onlyoffice/src/server/common/ASC.EventBus.RabbitMQ/DefaultRabbitMQPersistentConnection.cs:line 105
   at Polly.AsyncPolicy.<>c__DisplayClass44_0.<<ImplementationAsync>b__0>d.MoveNext()
--- End of stack trace from previous location ---
   at Polly.Retry.AsyncRetryEngine.ImplementationAsync[TResult](Func`3 action, Context context, ExceptionPredicates shouldRetryExceptionPredicates, ResultPredicates`1 shouldRetryResultPredicates, Func`5 onRetryAsync, CancellationToken cancellationToken, Int32 permittedRetryCount, IEnumerable`1 sleepDurationsEnumerable, Func`4 sleepDurationProvider, Boolean continueOnCapturedContext)
2025-02-18 06:20:23,320|WARN|[22]|ASC.EventBus.RabbitMQ.DefaultRabbitMQPersistentConnection - RabbitMQ Client could not connect after 8s|RabbitMQ.Client.Exceptions.BrokerUnreachableException: None of the specified endpoints were reachable
 ---> RabbitMQ.Client.Exceptions.AuthenticationFailureException: ACCESS_REFUSED - Login was refused using authentication mechanism PLAIN. For details see the broker logfile.
   at RabbitMQ.Client.Framing.Connection.StartAndTuneAsync(CancellationToken cancellationToken)
   at RabbitMQ.Client.Framing.Connection.OpenAsync(CancellationToken cancellationToken)
   at RabbitMQ.Client.Framing.AutorecoveringConnection.CreateAsync(ConnectionConfig config, IEndpointResolver endpoints, CancellationToken cancellationToken)
   at RabbitMQ.Client.ConnectionFactory.CreateConnectionAsync(IEndpointResolver endpointResolver, String clientProvidedName, CancellationToken cancellationToken)
   --- End of inner exception stack trace ---
2025-02-18 06:20:31,330|WARN|[10]|ASC.EventBus.RabbitMQ.DefaultRabbitMQPersistentConnection - RabbitMQ Client could not connect after 16s|RabbitMQ.Client.Exceptions.BrokerUnreachableException: None of the specified endpoints were reachable
My screen looks like (lots of greyed out buttons) and no “progress spinner” at bottom right
Any help appreciated.
Can i simple abort this old manual backup?
Thanks
Ivan
This is more serious and maybe related.
These TWO identity containers keep restarting, never going healthy.
The CPUs are pegged at 400%
The service is now unusable.
Any help needed, it was fine before 3.01
Error logs look like
{"date":"2025-02-18T17:02:11.590223129Z","@version":"1","message":"Application run failed","sourceContext":"org.springframework.boot.SpringApplication","threadId":"main","level":"ERROR","stack_trace":"c.r.c.AuthenticationFailureException: ACCESS_REFUSED - Login was refused using authentication mechanism PLAIN. For details see the broker logfile.\n\tat c.r.c.impl.AMQConnection.start(AMQConnection.java:395)\n\tat c.r.c.ConnectionFactory.newConnection(ConnectionFactory.java:1251)\n\tat c.r.c.ConnectionFactory.newConnection(ConnectionFactory.java:1198)\n\tat o.s.a.r.c.AbstractConnectionFactory.connectAddresses(AbstractConnectionFactory.java:668)\n\t... 44 frames truncated (including 42 common frames)\nWrapped by: o.s.a.AmqpAuthenticationException: com.rabbitmq.client.AuthenticationFailureException: ACCESS_REFUSED - Login was refused using authentication mechanism PLAIN. For details see the broker logfile.\n\tat o.s.a.r.s.RabbitExceptionTranslator.convertRabbitAccessException(RabbitExceptionTranslator.java:64)\n\tat o.s.a.r.c.AbstractConnectionFactory.createBareConnection(AbstractConnectionFactory.java:622)\n\tat o.s.a.r.c.CachingConnectionFactory.createConnection(CachingConnectionFactory.java:726)\n\tat o.s.a.r.c.ConnectionFactoryUtils.createConnection(ConnectionFactoryUtils.java:257)\n\t... 40 frames truncated (including 25 common frames)\nWrapped by: o.s.b.BeanInstantiationException: Failed to instantiate [org.springframework.amqp.rabbit.core.RabbitAdmin]: Factory method 'rabbitAdmin' threw exception with message: com.rabbitmq.client.AuthenticationFailureException: ACCESS_REFUSED - Login was refused using authentication mechanism PLAIN. For details see the broker logfile.\n\tat o.s.b.f.s.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:177)\n\tat o.s.b.f.s.ConstructorResolver.instantiate(ConstructorResolver.java:644)\n\t... 24 common frames omitted\nWrapped by: o.s.b.f.BeanCreationException: Error creating bean with name 'rabbitAdmin' defined in class path resource [com/asc/common/messaging/configuration/RabbitMQConfiguration.class]: Failed to instantiate [org.springframework.amqp.rabbit.core.RabbitAdmin]: Factory method 'rabbitAdmin' threw exception with message: com.rabbitmq.client.AuthenticationFailureException: ACCESS_REFUSED - Login was refused using authentication mechanism PLAIN. For details see the broker logfile.\n\tat o.s.b.f.s.ConstructorResolver.instantiate(ConstructorResolver.java:648)\n\tat o.s.b.f.s.ConstructorResolver.instantiateUsingFactoryMethod(ConstructorResolver.java:636)\n\tat o.s.b.f.s.AbstractAutowireCapableBeanFactory.instantiateUsingFactoryMethod(AbstractAutowireCapableBeanFactory.java:1337)\n\tat o.s.b.f.s.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:1167)\n\t... 21 frames truncated\n","applicationContext":"ASC.Identity.Authorization.API","instanceId":"58b2ff67a8b4"}
  .   ____          _            __ _ _
 /\\ / ___'_ __ _ _(_)_ __  __ _ \ \ \ \
( ( )\___ | '_ | '_| | '_ \/ _` | \ \ \ \
 \\/  ___)| |_)| | | | | || (_| |  ) ) ) )
  '  |____| .__|_| |_|_| |_\__, | / / / /
 =========|_|==============|___/=/_/_/_/
 :: Spring Boot ::                (v3.3.0)
{"date":"2025-02-18T17:02:44.089203446Z","@version":"1","message":"Application run failed","sourceContext":"org.springframework.boot.SpringApplication","threadId":"main","level":"ERROR","stack_trace":"c.r.c.AuthenticationFailureException: ACCESS_REFUSED - Login was refused using authentication mechanism PLAIN. For details see the broker logfile.\n\tat c.r.c.impl.AMQConnection.start(AMQConnection.java:395)\n\tat c.r.c.ConnectionFactory.newConnection(ConnectionFactory.java:1251)\n\tat c.r.c.ConnectionFactory.newConnection(ConnectionFactory.java:1198)\n\tat o.s.a.r.c.AbstractConnectionFactory.connectAddresses(AbstractConnectionFactory.java:668)\n\t... 44 frames truncated (including 42 common frames)\nWrapped by: o.s.a.AmqpAuthenticationException: com.rabbitmq.client.AuthenticationFailureException: ACCESS_REFUSED - Login was refused using authentication mechanism PLAIN. For details see the broker logfile.\n\tat o.s.a.r.s.RabbitExceptionTranslator.convertRabbitAccessException(RabbitExceptionTranslator.java:64)\n\tat o.s.a.r.c.AbstractConnectionFactory.createBareConnection(AbstractConnectionFactory.java:622)\n\tat o.s.a.r.c.CachingConnectionFactory.createConnection(CachingConnectionFactory.java:726)\n\tat o.s.a.r.c.ConnectionFactoryUtils.createConnection(ConnectionFactoryUtils.java:257)\n\t... 40 frames truncated (including 25 common frames)\nWrapped by: o.s.b.BeanInstantiationException: Failed to instantiate [org.springframework.amqp.rabbit.core.RabbitAdmin]: Factory method 'rabbitAdmin' threw exception with message: com.rabbitmq.client.AuthenticationFailureException: ACCESS_REFUSED - Login was refused using authentication mechanism PLAIN. For details see the broker logfile.\n\tat o.s.b.f.s.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:177)\n\tat o.s.b.f.s.ConstructorResolver.instantiate(ConstructorResolver.java:644)\n\t... 24 common frames omitted\nWrapped by: o.s.b.f.BeanCreationException: Error creating bean with name 'rabbitAdmin' defined in class path resource [com/asc/common/messaging/configuration/RabbitMQConfiguration.class]: Failed to instantiate [org.springframework.amqp.rabbit.core.RabbitAdmin]: Factory method 'rabbitAdmin' threw exception with message: com.rabbitmq.client.AuthenticationFailureException: ACCESS_REFUSED - Login was refused using authentication mechanism PLAIN. For details see the broker logfile.\n\tat o.s.b.f.s.ConstructorResolver.instantiate(ConstructorResolver.java:648)\n\tat o.s.b.f.s.ConstructorResolver.instantiateUsingFactoryMethod(ConstructorResolver.java:636)\n\tat o.s.b.f.s.AbstractAutowireCapableBeanFactory.instantiateUsingFactoryMethod(AbstractAutowireCapableBeanFactory.java:1337)\n\tat o.s.b.f.s.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:1167)\n\t... 21 frames truncated\n","applicationContext":"ASC.Identity.Authorization.API","instanceId":"58b2ff67a8b4"}
  .   ____          _            __ _ _
{"date":"2025-02-18T17:03:17.973078269Z","@version":"1","message":"Application run failed","sourceContext":"org.springframework.boot.SpringApplication","threadId":"main","level":"ERROR","stack_trace":"c.r.c.AuthenticationFailureException: ACCESS_REFUSED - Login was refused using authentication mechanism PLAIN. For details see the broker logfile.\n\tat c.r.c.impl.AMQConnection.start(AMQConnection.java:395)\n\tat c.r.c.ConnectionFactory.newConnection(ConnectionFactory.java:1251)\n\tat c.r.c.ConnectionFactory.newConnection(ConnectionFactory.java:1198)\n\tat o.s.a.r.c.AbstractConnectionFactory.connectAddresses(AbstractConnectionFactory.java:668)\n\t... 44 frames truncated (including 42 common frames)\nWrapped by: o.s.a.AmqpAuthenticationException: com.rabbitmq.client.AuthenticationFailureException: ACCESS_REFUSED - Login was refused using authentication mechanism PLAIN. For details see the broker logfile.\n\tat o.s.a.r.s.RabbitExceptionTranslator.convertRabbitAccessException(RabbitExceptionTranslator.java:64)\n\tat o.s.a.r.c.AbstractConnectionFactory.createBareConnection(AbstractConnectionFactory.java:622)\n\tat o.s.a.r.c.CachingConnectionFactory.createConnection(CachingConnectionFactory.java:726)\n\tat o.s.a.r.c.ConnectionFactoryUtils.createConnection(ConnectionFactoryUtils.java:257)\n\t... 40 frames truncated (including 25 common frames)\nWrapped by: o.s.b.BeanInstantiationException: Failed to instantiate [org.springframework.amqp.rabbit.core.RabbitAdmin]: Factory method 'rabbitAdmin' threw exception with message: com.rabbitmq.client.AuthenticationFailureException: ACCESS_REFUSED - Login was refused using authentication mechanism PLAIN. For details see the broker logfile.\n\tat o.s.b.f.s.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:177)\n\tat o.s.b.f.s.ConstructorResolver.instantiate(ConstructorResolver.java:644)\n\t... 24 common frames omitted\nWrapped by: o.s.b.f.BeanCreationException: Error creating bean with name 'rabbitAdmin' defined in class path resource [com/asc/common/messaging/configuration/RabbitMQConfiguration.class]: Failed to instantiate [org.springframework.amqp.rabbit.core.RabbitAdmin]: Factory method 'rabbitAdmin' threw exception with message: com.rabbitmq.client.AuthenticationFailureException: ACCESS_REFUSED - Login was refused using authentication mechanism PLAIN. For details see the broker logfile.\n\tat o.s.b.f.s.ConstructorResolver.instantiate(ConstructorResolver.java:648)\n\tat o.s.b.f.s.ConstructorResolver.instantiateUsingFactoryMethod(ConstructorResolver.java:636)\n\tat o.s.b.f.s.AbstractAutowireCapableBeanFactory.instantiateUsingFactoryMethod(AbstractAutowireCapableBeanFactory.java:1337)\n\tat o.s.b.f.s.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:1167)\n\t... 21 frames truncated\n","applicationContext":"ASC.Identity.Authorization.API","instanceId":"58b2ff67a8b4"}
  .   ____          _            __ _ _
type or paste code here
Rabbit is broken
2025-02-18 15:51:20.876149+00:00 [error] <0.92992.0> Error on AMQP connection <0.92992.0> (172.18.0.17:47936 → 172.18.0.18:5672, state: starting):
2025-02-18 15:51:20.876149+00:00 [error] <0.92992.0> PLAIN login refused: user ‘guest’ - invalid credentials
2025-02-18 15:51:20.877473+00:00 [info] <0.92992.0> closing AMQP connection <0.92992.0> (172.18.0.17:47936 → 172.18.0.18:5672 - BackupBackgroundTasks)
2025-02-18 15:51:25.395771+00:00 [info] <0.92997.0> accepting AMQP connection <0.92997.0> (172.18.0.25:36984 → 172.18.0.18:5672)
2025-02-18 15:51:25.399415+00:00 [info] <0.92997.0> connection <0.92997.0> (172.18.0.25:36984 → 172.18.0.18:5672) has a client-provided name: Notify
2025-02-18 15:51:25.399710+00:00 [error] <0.92997.0> Error on AMQP connection <0.92997.0> (172.18.0.25:36984 → 172.18.0.18:5672, state: starting):
2025-02-18 15:51:25.399710+00:00 [error] <0.92997.0> PLAIN login refused: user ‘guest’ - invalid credentials
2025-02-18 15:51:25.401183+00:00 [info] <0.92997.0> closing AMQP connection <0.92997.0> (172.18.0.25:36984 → 172.18.0.18:5672 - Notify)
2025-02-18 15:51:26.010918+00:00 [info] <0.93002.0> accepting AMQP connection <0.93002.0> (172.18.0.7:46994 → 172.18.0.18:5672)
2025-02-18 15:51:26.014724+00:00 [info] <0.93002.0> connection <0.93002.0> (172.18.0.7:46994 → 172.18.0.18:5672) has a client^C
2025-02-18 15:52:04.170488+00:00 [error] <0.93073.0> PLAIN login refused: user ‘guest’ - invalid credentials
2025-02-18 15:52:04.176311+00:00 [info] <0.93073.0> closing AMQP connection <0.93073.0> (172.18.0.14:40150 → 172.18.0.18:5672 - FilesService)
2025-02-18 15:52:04.381064+00:00 [info] <0.93078.0> accepting AMQP connection <0.93078.0> (172.18.0.20:40334 → 172.18.0.18:5672)
2025-02-18 15:52:04.453374+00:00 [info] <0.93078.0> connection <0.93078.0> (172.18.0.20:40334 → 172.18.0.18:5672) has a client-provided name: rabbitConnectionFactory#23b31c6c:0
2025-02-18 15:52:04.453744+00:00 [error] <0.93078.0> Error on AMQP connection <0.93078.0> (172.18.0.20:40334 → 172.18.0.18:5672, state: starting):
2025-02-18 15:52:04.453744+00:00 [error] <0.93078.0> PLAIN login refused: user ‘guest’ - invalid credentials
2025-02-18 15:52:04.455218+00:00 [info] <0.93078.0> closing AMQP connection <0.93078.0> (172.18.0.20:40334 → 172.18.0.18:5672 - rabbitConnectionFactory#23b31c6c:0)
2025-02-18 15:52:08.189560+00:00 [info] <0.93083.0> accepting AMQP connection <0.93083.0> (172.18.0.14:48004 → 172.18.0.18:5672)
Dear @ivan
How exactly did you perform the upgrade process? I’ve checked docker installation on my Ubuntu 24.04 server, all things are OK, the mentioned containers are running and the backup creation is OK.
According to the provided logs, it seems that the issue is related to RabbitMQ. Could you please provide us with entire DocSpace logs folder (/var/lib/docker/volumes/onlyoffice_log_data/_data/
Additionally, please go RabbitMQ container (docker exec -it ID bash) and check its status with rabbitmqctl status command. Please show us the output result.
H Alexandre.
As root:
wget http://download.onlyoffice.com/docspace/docspace-install.sh
bash docspace-install.sh -u true
(there were no on screen errors)
rabbit.log (2.7 KB)
logs.docx (6.5 MB)
Please rename logs.docx to logs.tar.gz and gunzip to the contents of full logfolder
many thanks
Ivan
Hello @ivan
Thank you for the provided logs.
Please try to restart RabbitMQ container (docker restart ID_of_container command). If it doesn’t help, go inside the container (docker exec -it ID bash) and show us the output of these commands:
rabbitmqctl list_users
rabbitmqctl list_permissions
May we close this ticket and continue it here Unable to launch on demand backup of space as the problem persists.
root@e3a666278b42:/# rabbitmqctl list_users
Listing users …
user tags
guest [administrator]
root@e3a666278b42:/# rabbitmqctl list_permissions
Listing permissions for vhost “/” …
user configure write read
guest .* .* .*
Can we please close this ticket.
I have added more info to the new ticket below as the backup situation has degraded from “hung” to “unable to launch one at all”
many thanks
Ivan
Ok, this thread is closed, let’s communicate in the other one.
