My requirement is to click the button to copy all the contents of file A on the right to the cursor of file B on the left. How should it be implemented?
This is a partial code block that I have implemented
insertElement() {
var projectEditorConnector = this.projectEditor.createConnector();
var elementEditorConnector = this.elementEditor.createConnector();
elementEditorConnector.callCommand(
function () {
sessionStorage.removeItem("elementTemp");
sessionStorage.setItem(
"elementTemp",
oDocument.ToJSON(true, true, true, true, true, true)
function () {
console.log("callback command");
projectEditorConnector.callCommand(
function () {
var json = Api.FromJSON(sessionStorage.getItem("elementTemp"));
oDocument.InsertContent(json);
function () {
I have reviewed the document introducing the global variable GlobalVariable, but I may report an error stating that GlobalVariable is not defined, so I used sessionStorage. Is there a better solution to implement it?
Even so, if I configure config. type=“embedded”, the above method cannot be implemented, and callCommand will not execute
