Hi, Thanks for looking into this.
There is no specific error shown in Thunderbird, it just asks for the password again. My CalDAV app on android say Authentication Error.
The domain was already set up on the portal settings.
Here is the radicale logs with my domain and my email replaced with *s.
I picked a calendar from the web interface and got the CalDAV link and then added that to Thunderbird and the log in failed, I then checked the same password in an incognito window to log into the web interface again successfully.
These are all the entries in the radicale.log from doing that.
2021-10-26 19:32:43,872 - [7fadfffff700] INFO: GET request for '/nick@************.**.**@docs.************.**.**/62417450-a36d-4109-8036-143a24e7af8f' received from '172.18.0.1' (forwarded by 127.0.0.1)
2021-10-26 19:32:43,875 - [7fadfffff700] INFO: Auth token: 'ASC radicale:20211026193243:ACkscjTwbF/yluu70hkqpNc+e/M='
2021-10-26 19:32:43,878 - [7fadfffff700] INFO: Remote host: 'docs.************.**.**'
2021-10-26 19:32:43,901 - [7fadfffff700] INFO: Successful login: 'nick@************.**.**' -> 'nick@************.**.**@docs.************.**.**'
2021-10-26 19:32:48,064 - [7fadfffff700] INFO: GET response status for '/nick@************.**.**@docs.************.**.**/62417450-a36d-4109-8036-143a24e7af8f' in 4.193 seconds: 200 OK
2021-10-26 19:33:29,751 - [7fadfffff700] INFO: PROPFIND request for '/nick@************.**.**@docs.************.**.**/62417450-a36d-4109-8036-143a24e7af8f/' with depth '0' received from '103.242.25.144' (forwarded by 127.0.0.1) using 'Mozilla/5.0 (X11; Linux x86_64; rv:78.0) Gecko/20100101 Thunderbird/78.13.0'
2021-10-26 19:33:29,755 - [7fadfffff700] INFO: Rights: '':'nick@************.**.**@docs.************.**.**/62417450-a36d-4109-8036-143a24e7af8f' doesn't match any section
2021-10-26 19:33:29,757 - [7fadfffff700] INFO: Rights: '':'nick@************.**.**@docs.************.**.**' doesn't match any section
2021-10-26 19:33:29,760 - [7fadfffff700] INFO: Access to '/nick@************.**.**@docs.************.**.**/62417450-a36d-4109-8036-143a24e7af8f/' denied for anonymous user
2021-10-26 19:33:29,763 - [7fadfffff700] INFO: PROPFIND response status for '/nick@************.**.**@docs.************.**.**/62417450-a36d-4109-8036-143a24e7af8f/' with depth '0' in 0.012 seconds: 401 Unauthorized
2021-10-26 19:33:40,524 - [7fadfffff700] INFO: PROPFIND request for '/nick@************.**.**@docs.************.**.**/62417450-a36d-4109-8036-143a24e7af8f/' with depth '0' received from '103.242.25.144' (forwarded by 127.0.0.1) using 'Mozilla/5.0 (X11; Linux x86_64; rv:78.0) Gecko/20100101 Thunderbird/78.13.0'
2021-10-26 19:33:40,528 - [7fadfffff700] INFO: Auth token: 'ASC radicale:20211026193340:CG29PSsGsyHWzz8yiiCmDaH18KE='
2021-10-26 19:33:40,531 - [7fadfffff700] INFO: Remote host: 'docs.************.**.**'
2021-10-26 19:33:40,547 - [7fadfffff700] ERROR: Error login response: {'value': 'false', 'message': 'Error: TrustFailure (Authentication failed, see inner exception.)'}
2021-10-26 19:33:40,550 - [7fadfffff700] INFO: Failed login attempt: 'nick@************.**.**'
2021-10-26 19:33:41,055 - [7fadfffff700] INFO: PROPFIND response status for '/nick@************.**.**@docs.************.**.**/62417450-a36d-4109-8036-143a24e7af8f/' with depth '0' in 0.531 seconds: 401 Unauthorized
2021-10-26 19:33:41,102 - [7fadfffff700] INFO: PROPFIND request for '/nick@************.**.**@docs.************.**.**/62417450-a36d-4109-8036-143a24e7af8f/' with depth '0' received from '103.242.25.144' (forwarded by 127.0.0.1) using 'Mozilla/5.0 (X11; Linux x86_64; rv:78.0) Gecko/20100101 Thunderbird/78.13.0'
2021-10-26 19:33:41,106 - [7fadfffff700] INFO: Auth token: 'ASC radicale:20211026193341:jgvrUN7+OW9knFWLkrezz9VGWvA='
2021-10-26 19:33:41,109 - [7fadfffff700] INFO: Remote host: 'docs.************.**.**'
2021-10-26 19:33:41,124 - [7fadfffff700] ERROR: Error login response: {'value': 'false', 'message': 'Error: TrustFailure (Authentication failed, see inner exception.)'}
2021-10-26 19:33:41,128 - [7fadfffff700] INFO: Failed login attempt: 'nick@************.**.**'
2021-10-26 19:33:42,111 - [7fadfffff700] INFO: PROPFIND response status for '/nick@************.**.**@docs.************.**.**/62417450-a36d-4109-8036-143a24e7af8f/' with depth '0' in 1.009 seconds: 401 Unauthorized
