ASC - System.Runtime.Serialization.SerializationException
I see and error in web.log that is new since my upgrade
ii onlyoffice-communityserver 12.5.1.1837
ii onlyoffice-controlpanel 3.5.0.516
ii onlyoffice-documentserver 7.3.3-49~stretch
ii onlyoffice-xmppserver 12.0.0.126
Any ideas ? JWT related?
2023-05-23 18:51:02,411 ERROR [19] localhost - ASC - System.Runtime.Serialization.SerializationException: There was an error deserializing the object of type ASC.Core.Tenants.TenantCookieSettings. The token '"' was expected but found 'â'. ---> System.Xml.XmlException: The token '"' was expected but found 'â'.
  at System.Xml.XmlExceptionHelper.ThrowXmlException (System.Xml.XmlDictionaryReader reader, System.String res, System.String arg1, System.String arg2, System.String arg3) [0x0007c] in <5276c6fdd550403cbd27611ca6f2592a>:0
  at System.Xml.XmlExceptionHelper.ThrowXmlException (System.Xml.XmlDictionaryReader reader, System.String res, System.String arg1, System.String arg2) [0x00000] in <5276c6fdd550403cbd27611ca6f2592a>:0
  at System.Xml.XmlExceptionHelper.ThrowTokenExpected (System.Xml.XmlDictionaryReader reader, System.String expected, System.Char found) [0x0000e] in <5276c6fdd550403cbd27611ca6f2592a>:0
  at System.Runtime.Serialization.Json.XmlJsonReader.ReadServerTypeAttribute (System.Boolean consumedObjectChar) [0x00027] in <5276c6fdd550403cbd27611ca6f2592a>:0
  at System.Runtime.Serialization.Json.XmlJsonReader.ReadAttributes () [0x000d1] in <5276c6fdd550403cbd27611ca6f2592a>:0
  at System.Runtime.Serialization.Json.XmlJsonReader.ReadNonExistentElementName (System.Xml.StringHandleConstStringType elementName) [0x0005c] in <5276c6fdd550403cbd27611ca6f2592a>:0
  at System.Runtime.Serialization.Json.XmlJsonReader.Read () [0x00118] in <5276c6fdd550403cbd27611ca6f2592a>:0
  at System.Xml.XmlBaseReader.IsStartElement () [0x0001c] in <5276c6fdd550403cbd27611ca6f2592a>:0
  at System.Xml.XmlBaseReader.IsStartElement (System.Xml.XmlDictionaryString localName, System.Xml.XmlDictionaryString namespaceUri) [0x0002a] in <5276c6fdd550403cbd27611ca6f2592a>:0
  at System.Runtime.Serialization.XmlReaderDelegator.IsStartElement (System.Xml.XmlDictionaryString localname, System.Xml.XmlDictionaryString ns) [0x00032] in <5276c6fdd550403cbd27611ca6f2592a>:0
  at System.Runtime.Serialization.XmlObjectSerializer.IsRootElement (System.Runtime.Serialization.XmlReaderDelegator reader, System.Runtime.Serialization.DataContract contract, System.Xml.XmlDictionaryString name, System.Xml.XmlDictionaryString ns) [0x0000a] in <5276c6fdd550403cbd27611ca6f2592a>:0
  at System.Runtime.Serialization.Json.DataContractJsonSerializer.InternalIsStartObject (System.Runtime.Serialization.XmlReaderDelegator reader) [0x00013] in <5276c6fdd550403cbd27611ca6f2592a>:0
  at System.Runtime.Serialization.Json.DataContractJsonSerializer.InternalReadObject (System.Runtime.Serialization.XmlReaderDelegator xmlReader, System.Boolean verifyObjectName) [0x00034] in <5276c6fdd550403cbd27611ca6f2592a>:0
  at System.Runtime.Serialization.XmlObjectSerializer.InternalReadObject (System.Runtime.Serialization.XmlReaderDelegator reader, System.Boolean verifyObjectName, System.Runtime.Serialization.DataContractResolver dataContractResolver) [0x00000] in <5276c6fdd550403cbd27611ca6f2592a>:0
  at System.Runtime.Serialization.XmlObjectSerializer.ReadObjectHandleExceptions (System.Runtime.Serialization.XmlReaderDelegator reader, System.Boolean verifyObjectName, System.Runtime.Serialization.DataContractResolver dataContractResolver) [0x00072] in <5276c6fdd550403cbd27611ca6f2592a>:0
type or paste code here
Looks like this old .NET issue
Hi @ivan
Are there any consequences of this error?
When loading “excel” sheets I see a lag as web.log gets written to heavily on this “soft” error.
It’s NON fatal Nikolas - so NOT high priority. But, its indicative of some SERDES issue.
Thanks
ivan
Can I ask you to provide an example of the Excel file that causes an error when uploading?
Hi Nikolas…
This issue is back again…
Leads to VERY VERY slow appearance of the document for edit in browser (chrome or firefox)
making editing very tedious :frowning:
Ubuntu 22.04 + latest patches
NEW kernel 6.2.0-26-generic #26~22.04.1-Ubuntu
dpkg --list|grep onlyoffice|awk ‘{print $2 i" " $3 " " $4}’
onlyoffice-documentserver 7.4.1-36
errors here…
web.log and XLSX file attachedweb.docx (7.1 KB)
XL file used here
COPY-DONT-EDIT-Day-Month-Year-HUBNAME.xlsx (8.7 KB)
DO
DOTNET SETUP
dotnet-apphost-pack-6.0 6.0.21-1
dotnet-apphost-pack-7.0 7.0.10-1
dotnet-host 7.0.10-1
dotnet-hostfxr-6.0 6.0.21-1
dotnet-hostfxr-7.0 7.0.10-1
dotnet-runtime-6.0 6.0.21-1
dotnet-runtime-7.0 7.0.10-1
dotnet-runtime-deps-6.0 6.0.21-1
dotnet-runtime-deps-7.0 7.0.10-1
dotnet-sdk-6.0 6.0.413-1
dotnet-sdk-7.0 7.0.400-1
dotnet-targeting-pack-6.0 6.0.21-1
dotnet-targeting-pack-7.0 7.0.10-1
Interesting I have 6 and 7 here !
Hi @ivan
Let’s be clear.
  • Does the problem only occur when opening a certain file?
  • Send the output of the command: dotnet --info
  • Did the problem occur after the update?
Ah… It seems to be ONE file (embarassed to admit)
It was generated from excel on windows I think. I can track that down,
But it did happen after dotnet 7
That may be a coincidence.
Thanks
Ivan
PS I feel you canm put this to low priority for now unless something obvious shows up in the XLS file I uploaded. I can “santize” them perhaps before uploading them into OO.
root@onlyoffice:~# dotnet --info
.NET SDK:
Version: 7.0.400
Commit: 73bf45718d
Runtime Environment:
OS Name: ubuntu
OS Version: 20.04
OS Platform: Linux
RID: ubuntu.20.04-x64
Base Path: /usr/share/dotnet/sdk/7.0.400/
Host:
Version: 7.0.10
Architecture: x64
Commit: a6dbb800a4
.NET SDKs installed:
6.0.413 [/usr/share/dotnet/sdk]
7.0.400 [/usr/share/dotnet/sdk]
.NET runtimes installed:
Microsoft.AspNetCore.App 6.0.21 [/usr/share/dotnet/shared/Microsoft.AspNetCore .App]
Microsoft.AspNetCore.App 7.0.10 [/usr/share/dotnet/shared/Microsoft.AspNetCore .App]
Microsoft.NETCore.App 6.0.21 [/usr/share/dotnet/shared/Microsoft.NETCore.App]
Microsoft.NETCore.App 7.0.10 [/usr/share/dotnet/shared/Microsoft.NETCore.App]
Other architectures found:
None
Environment variables:
Not set
global.json file:
Not found
Learn more:
dotnet command - .NET CLI | Microsoft Learn
Download .NET:
.NET Downloads (Linux, macOS, and Windows)
