docker images
REPOSITORY TAG IMAGE ID CREATED SIZE
onlyoffice/documentserver 6.2.2 0714325e9cf7 5 months ago 3.04GB
input terminal
docker run -i -t -d -p 8423:80 --restart=always -v /data/onlyoffice/DocumentServer/logs:/var/log/onlyoffice -v /data/onlyoffice/DocumentServer/data:/var/www/onlyoffice/Data -v /data/onlyoffice/DocumentServer/lib:/var/lib/onlyoffice -v /data/onlyoffice/DocumentServer/db:/var/lib/postgresql onlyoffice/documentserver:6.2.2
docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
0cf9c60ba0d5 onlyoffice/documentserver:6.2.2 “/app/ds/run-documen…” 34 minutes ago Up 20 minutes 443/tcp, 0.0.0.0:8423->80/tcp trusting_easley
after new DocsAPI.DocEditor in .js to load docx file in browse
wrong appears:
and the log is :
2024/01/02 16:57:08 [error] 6834#6834: *110 connect() failed (111: Connection refused) while connecting to upstream, client: 2.32.244.1, server: , request: “GET /6.2.2-21/doc/1704189933968/c/info?t=1704214629070 HTTP/1.1”, upstream: “127.0.0.1:8000/doc/1704189933968/c/info”, host: “2.46.150.224:8423”, referrer: “2.46.150.224:8423/6.2.2-21/web-apps/apps/documenteditor/main/index.html?_dc=5.5.1-76&lang=zh-CN&customer=ONLYOFFICE&frameEditorId=placeholder&compact=true?1704214524371”
the problem must come from here: 127.0.0.1:8000
but i don’t know how to fix,
in docker
cat /etc/nginx/includes/ds-docservice.conf
Allow internal service only from 127.0.0.1
location ~* ^(/[\d]+.[\d]+.[\d]+[.|-][\d]+)?/(info|internal)(/.*)$ {
allow 127.0.0.1;
deny all;
proxy_pass http://docservice/$2$3;
