I´ve got a deb workspace installation on Ubuntu 20.04.4 LTS. The server is a virtual kvm machine. The installation was reachable by https with letsencrypt certificate. After update to onlyoffice-communityserver version 11.6.0.1620 the webgui is no longer reachable. Nginx service is running. When the server is rebooted there is an error 502 app crash webpage for some seconds. Afterwards I get only ERR_INVALID_RESPONSE. Is there any advice? What can I do now to get it reachable again without loosing the workspace data?
Additional Information: the workspace was installed by usinig minmal Ubuntu installation and running sudo bash workspace-install.sh -ims false
The installation was no problem but I don´t know how to solve the current problem.
Hello Holger,
Please send me the config file /etc/nginx/sites-available/onlyoffice
Also please check if monoserve is running: service monoserve status
If it is down, restart it.
Hallo Carl, thx for advice.
Status of Monoserve is active.
root@work:~# service monoserve status
● monoserve.service - FastCGI Mono server
Loaded: loaded (/lib/systemd/system/monoserve.service; enabled; vendor preset: enabled)
Active: active (running) since Wed 2022-05-04 12:11:41 CEST; 701ms ago
Process: 1893743 ExecStartPre=/bin/bash -c test -e /var/run/onlyoffice || install -m 755 -o onlyoffice -g nginx -d /var/run/onlyoffice; rm -f /var/run/onlyoffice/onlyoffice.socket /var/www/onlyoffice/WebStudio/mono_crash* /var/www/onlyoffice/WebStudio/core.*; (code=exit>
Main PID: 1893745 (mono)
Tasks: 3 (limit: 7060)
Memory: 13.1M
CGroup: /system.slice/monoserve.service
└─1893745 /usr/bin/mono /usr/lib/hyperfastcgi/4.0/HyperFastCgi.exe /config=/etc/hyperfastcgi/onlyoffice /logfile=/var/log/onlyoffice/onlyoffice.log /loglevels=Error
Mai 04 12:11:41 work systemd[1]: Starting FastCGI Mono server...
Mai 04 12:11:41 work systemd[1]: Started FastCGI Mono server.
lines 1-12/12 (END)
Here is the content of sites-available/onlyoffice:
upstream fastcgi_backend_apisystem {
server unix:/var/run/onlyoffice/onlyofficeApiSystem.socket;
keepalive 32;
upstream fastcgi_backend {
server unix:/var/run/onlyoffice/onlyoffice.socket;
keepalive 32;
fastcgi_cache_path /var/cache/nginx/onlyoffice
levels=1:2
keys_zone=onlyoffice:256m
max_size=1024m
inactive=1d;
map $http_host $this_host {
"" $host;
default $http_host;
map $http_x_forwarded_proto $the_scheme {
default $http_x_forwarded_proto;
"" $scheme;
map $http_x_forwarded_host $the_host {
default $http_x_forwarded_host;
"" $this_host;
map $request_uri $header_access_control_allow_origin {
~*^/(api\/2.0|products\/crm\/httphandlers\/webtoleadfromhandler.ashx|products\/files\/httphandlers\/filehandler.ashx|products\/files\/chunkeduploader.ashx|thirdparty\/plugin) "*";
default "";
map $request_uri $header_x_frame_options {
~*^/(favicon\.ico|products\/files\/share\.aspx|products\/files\/saveas\.aspx|products\/files\/filechoice\.aspx|products\/files\/doceditor\.aspx|thirdparty\/plugin) "";
~*^/ds-vpath "SAMEORIGIN";
default "SAMEORIGIN";
server {
listen 80;
charset utf-8;
add_header Access-Control-Allow-Origin $header_access_control_allow_origin;
add_header X-Frame-Options $header_x_frame_options;
large_client_header_buffers 4 16k;
set $X_REWRITER_URL $the_scheme://$the_host;
if ($http_x_rewriter_url != '') {
set $X_REWRITER_URL $http_x_rewriter_url ;
include /etc/nginx/includes/onlyoffice-communityserver-*.conf;
Thank you.
Please specify how you installed the update? Did you use the installation script?
It seems the nginx config was overwritten as there is no listen 443
section that is responsible for HTTPS connection.
Please follow the guide to re-enable HTTPS:
https://helpcenter.onlyoffice.com/installation/groups-https-linux.aspx
Hello Carl,
the update was installed via
apt update
apt upgrade
Is that not the recommended way for updating?
I followed the linked guide and added to sites-available/onlyoffice:
server {
listen 0.0.0.0:443 ssl http2;
listen [::]:443 ssl http2 default_server;
charset utf-8;
server_tokens off;
## Increase this if you want to upload large attachments
client_max_body_size 100m;
ssl_certificate /var/www/onlyoffice/Data/certs/onlyoffice.crt;
ssl_certificate_key /var/www/onlyoffice/Data/certs/onlyoffice.key;
ssl_verify_client off;
ssl_client_certificate www/onlyoffice/Data/certs/onlyoffice.crt;
ssl_session_timeout 1d;
ssl_session_cache shared:MozSSL:10m; # about 40000 sessions
ssl_session_tickets off;
ssl_protocols TLSv1.2;
ssl_ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384;
ssl_prefer_server_ciphers off;
add_header Strict-Transport-Security "max-age=63072000; includeSubDomains; preload" always;
add_header X-Content-Type-Options nosniff;
ssl_stapling on;
ssl_stapling_verify on;
ssl_trusted_certificate /var/www/onlyoffice/Data/certs/stapling.trusted.crt;
resolver 8.8.8.8 8.8.4.4 127.0.0.11 valid=300s; # Can change to your DNS resolver if desired
resolver_timeout 10s;
ssl_dhparam /var/www/onlyoffice/Data/certs/dhparam.pem;
That did unfortunately not solve my problem nor running the script:
sudo bash /var/www/onlyoffice/Tools/default-onlyoffice-ssl.sh
I rebooted the server for restarting all services but the Webgui is still not reachable. For a short time the webserver shows a webpage with “Error 502. App Crash”.
The recommended way of updating a deb/rpm package installation of Workspace is by using the installation script.
bash workspace-install.sh -u true
Please try executing it and let me know the results.
I executed the script and rebooted the server. But again I get “Error 502. App Crash”.
Please check monoserve status again.
Status of monoserve is up and running.
Active: active (running) since Wed 2022-05-04 14:59:03 CEST; 37s ago
Process: 3822 ExecStartPre=/bin/bash -c test -e /var/run/onlyoffice || install -m 755 -o onlyoffice -g nginx -d /var/run/onlyoffice; rm -f /var/run/onlyoffice/onlyoffice.socket /var/www/onlyoffice/WebStudio/mono_crash* /var/www/onlyoffice/WebStudio/core.*; (code=exited,>
Main PID: 3829 (mono)
Tasks: 52 (limit: 7060)
Memory: 217.1M
└─3829 /usr/bin/mono /usr/lib/hyperfastcgi/4.0/HyperFastCgi.exe /config=/etc/hyperfastcgi/onlyoffice /logfile=/var/log/onlyoffice/onlyoffice.log /loglevels=Error
Mai 04 14:59:03 work systemd[1]: Starting FastCGI Mono server...
Mai 04 14:59:03 work systemd[1]: Started FastCGI Mono server.
Mai 04 14:59:04 work hyperfastcgi4[3829]: WebConfigurationManager's LRUcache Size overriden to: 2000 (via MONO_ASPNET_WEBCONFIG_CACHESIZE)
Mai 04 14:59:44 work systemd[1]: Stopping FastCGI Mono server...
Mai 04 14:59:44 work hyperfastcgi4[3829]: host-list.c:38: register_host(): (null):0:/:/var/www/onlyoffice/WebStudio host=0x7f63d84c6320 pinned_host=0x7f63d84c6320 domain=0x55753c53e080
Mai 04 14:59:44 work hyperfastcgi4[3829]: libev.c:476: Listen(): libevent version: 2.1.11-stable
Mai 04 14:59:44 work hyperfastcgi4[3829]: libev.c:490: Listen(): libevent is using epoll for events.
Mai 04 14:59:44 work hyperfastcgi4[3829]: libev.c:319: cmd_error(): Remote host disconnected from fd 15.
Mai 04 14:59:44 work hyperfastcgi4[3829]: libev.c:319: cmd_error(): Remote host disconnected from fd 38.
Mai 04 14:59:44 work hyperfastcgi4[3829]: libev.c:319: cmd_error(): Remote host disconnected from fd 42.
Mai 04 14:59:44 work hyperfastcgi4[3829]: libev.c:447: Shutdown(): Goodbye.
Mai 04 14:59:44 work systemd[1]: monoserve.service: Succeeded.
Mai 04 14:59:44 work systemd[1]: Stopped FastCGI Mono server.
Mai 04 14:59:44 work systemd[1]: Starting FastCGI Mono server...
Mai 04 14:59:44 work systemd[1]: Started FastCGI Mono server.
Send me all logs from /var/log/onlyoffice/
There are many log files in that folder. Can I send a tar archive file via pm? Which adress shall I use?
Yes, you can upload an archive with logs to some hosting and send me the link via pm.
OK - now I found the “Start a message” button.
