ONLYOFFICE Docs v7.3 released: enhanced forms, SmartArt, new security settings, Watch Window, and more
Workspace-install.sh changing port 443
I’m doing an docker installation using the workspace-install.sh script. I need to change port 80 and 443. Doing this “bash workspace-install.sh -ims false -cp 8282”. So port 80 becomes 8282. But how do I change 443 to 4430 ?
Hello @mala
Sorry for the late reply.
Currently, flag -cp allows to change port 80 only.
I’m looking for a workaround that can be used to change 443 port too. I will update this thread once I get any results.
Hello again @mala
Here is the workaround solution that works.
First, you will need to download alternative script that executes installation of Workspace:
wget https://download.onlyoffice.com/install/install.sh
Open this script and find next section to change the port:
	if [ "$RUN_COMMUNITY_SERVER" == "true" ]; then
		args=();
		args+=(--name "$COMMUNITY_CONTAINER_NAME");
		args+=(-p "$COMMUNITY_PORT:80");
		args+=(-p <your_port>:443);
		args+=(-p 5222:5222);
		args+=(--cgroupns host);
Where <your_port> is your desired SSL port for Docker container.
After that run the script specifying -it WORKSPACE flag to install free version of ONLYOFFICE Workspace like that:
bash install.sh -ims false -cp 8282 -it WORKSPACE
When script is finished, you can check the port forwarding by enlisting all Docker containers with command docker ps.
Important note: in this scenario if alternative script is used you will have to update your Workspace portal with this exact script in future with flag -u true.
