Workspace Community error - Settings not saving
For feature suggestions, describe the result you would like to achieve in detail:
Community Server/Control Panel version:
Type of installation of Workspace (docker, deb/rpm, exe)
OS:
Browser version:
In my fresh OnlyOffice Workspace Community Server (DigitalOcean 1-click setup) instance, i’m unable to enable/disable modules.
Every time i make a change and save, and refresh the page, the default settings appear!
:point_up_2:
@anyone?
Hello @shrey
Do you mean portal settings > Common > Modules&Tools menu? Could you please record a video file while you are reproducing the situation?
Hi there.
Upon checking again, it seems to be working fine.
Must have been some ‘user error’ on my part!
