Hi
Currently, when you change a text property (for instance the line spacing), using tab does not set the focus on the next property field (here the space before paragraph) but add a tab in the text.
From a UI standpoint, I think it would be logical that using tab allow the user to go through the different text-property fields.
Thanks for the analysis of this suggestion.
