Hi,
In a doc, I select 4 lines.
I add bullet points.
Issue : bullet points don’t have the same size :
File:
MHF - P1-S4 - Atelier 1.docx (23.5 KB)
Thanks
Hi,
File:
Thanks
Hello @arcqus
Could you please provide us with original file? I mean before your attempt to change bullets. Your provided one already has changes.
Sorry
No, I haven’t kept it.
Understood, we are checking the situation.
Hello @arcqus
We have checked the provided file. The situation is related to file itself and it have been reproduced in different editors. Unfortunately, there’s nothing we can do on our side. It seems that bullet size is related to font size which was used for this line.
ok, many thanks for your analysis.
