I’ve installed OnlyOffice 8.3.1.25 on my arm server with docker and configured my ngnix server to provide https (https://docs.plord.co.uk). The welcome page works as does the example.
I also installed the wordpress plugin 2.2.0 and setup access -
Dear @plord
We are trying to reproduce the issue, but without luck so far. However, we have noticed ‘Block Visibility’ in your screenshot. Is it some additional plugin? Could you please provide a link to it?
Additionally, please try to disable it and double-check the situation.
Dear @plord
Thank you for valuable data! We have found a bug and we have started working on it.
The bug is related to Astra theme that you are using (Appearance → Themes). As a workaround solution, please try switching to different theme.
Additionally, we will notify you once the fix is released.
Ah, brilliant, many thanks. Yes, switching to a different theme gets embedded working but messes up my site!, so I would prefer to keep astra if I can.
