Do you want to: Suggest a feature
For feature suggestions, describe the result you would like to achieve in detail: Right now, with WP connector, the JWT and host are visible on the dashboard for each site, which works in single site instances. My question or suggestion is, to modify the plugin in a way that enables movin connector settings to network dashboard, when using multi site wordpress instance. so entire instance is configured once and only network admins have access to it’s settings
Document Server version: 7.5.0
Connector version: 1.0.2
OS: LINUX ALMA 8
Browser version: firefox 122.0.1
hey @gemqueuer
We’ve noted your suggestion, but unfortunately, I can’t tell you when it will be implemented.
I can tell you that personally, I liked your suggestion!
