WOPI URL Setting
I’m trying to integrate OnlyOffice with our solution(different local server) but the problem is in the CSP Header. When attempting to edit a file the page is blank.
Upon checking developer tools. It is for some reason pointing to an HTTPS url, I don’t know where this setting is coming from, I’m pretty sure in both local/default.json files the host should be set on localhost/127.0.0.1 . We are testing locally via HTTP for now.
https://web-apps/apps/api.documents/api.js
1.) It should be in http not HTTPS.
2.) URL should be http://OOServerIP/web-apps
Please guide me where this setting comes from.
Hello @vill
Please refer to the general documentation on using WOPI for integration:
In general, please share installation type of Document Server and its version.
