Wont paste copied text
When I copy text from outside the app and try to paste in the ONLYOFFICE documents app it does not give an option to paste. When I hold my finger on the screen and wait for options to come up it includes the option to copy but not paste.
Document Server version: dont understand
Type of installation of the Document Server (docker, deb/rpm, exe, please point us to the installation guide that you used as well: I dont understand what this means
OS: Android 8.0.0
I will try upload video if I can but I dont know how yet and am trying to find out
Hello @Azariah5, please provide the following additional info:
  1. The version of Onlyoffice Documents app being used (as I understand, you are using mobile version of the Editor, right?). You can check the version by viewing the info about the app in the settings
  2. What device are you using?
  3. If possible, please record the screen while reproducing the issue showing from where and how you copy and paste
Samsung galaxy s7 edge
App info - Version 8.3.1
I dont think i can upload a video because i dont have screen record on my mobile. I have another device which has screen record but i dont have ONLYOFFICE on it and I do not think it will be compatible with the device.
Alright, we are currently checking, please wait
Hello @Azariah5, we haven’t been able to reproduce the problem so far, please try updating to the latest 8.3.2 version of the mobile app, then, in case the issue stays, please make a recording showing the issue reproduction
