I am not able to decrease the window height to less than ~480 pixels, since I updated onlyoffice recently
I used to be able to adjust height as much as I wanted, which was VERY useful for arranging the windows on my screen, now it is a hassle. There was a width restriction before, but not a height restriction.
can I fix this somehow? is this intended?
What OS are you using? (and its version)
I’ve tried it in 2 PCs so far, both do it, one has Windows 10 (up-to-date), the other has Windows 7.
Thank you for sharing, we are currently analysing the issue
The window minimum size (minimum height) restriction has been indeed introduced on the latest version, unfortunately, there is no way to make the window smaller now
Wondering what purpose does it serve to have a restriction? Excel doesn’t have a restriction either.
Any chance they will introduce an option to disable it on the next update or something?
Really messes with my window organisation, is there an archive with files from older versions for me to install?
EDIT: found the older versions on github, hope they remove this or make it optional in the future…
Unfortunately, I cannot say anything particular about the reason, but it is how it has been designed. Thank you for your opinion on this change, we will take it into consideration
