I can’t seem to find an api to disable editing. I only found that in word can be set by “SetLock” can not edit. But not in Spreadsheet API
Hello @tudou
Please specify your whole usage scenario for this query. Are you trying to disable editing of all workbook content?
Thank you for your reply. I would like to prohibit a certain column or line from being editable. For example, I want to stress that the second column cannot be edited, and forbid that the first row cannot be edited.
I’m afraid there is no way set up such editing restrictions logic in table in a regular DOCX document.
Isn’t the sheet in excell not working?
In spreadsheet editor you can indeed protect range, but the question is about simple tables in the document editor, isn’t it?
