WebSocket Error in OnlyOffice - 502 Bad Gateway
I am experiencing an issue when trying to load documents in OnlyOffice. The DevTools console shows WebSocket connection failures with the following error:
WebSocket connection to ‘ws://127.0.0.1:8888/…’ failed
Failed to load resource: the server responded with a status of 502 (Bad Gateway)
Additionally, multiple requests to /socket.io/ also return the 502 Bad Gateway error.
The server is running locally on port 8888. Has anyone encountered this issue before or has any suggestions for a solution?
Hello @emanueldev,
Please specify if you are using a reverse proxy in front of the Document Server, if yes, please specify which one
I’m using Nginx
Please provide your nginx proxy config
