ONLYOFFICE Docs v7.3 released: enhanced forms, SmartArt, new security settings, Watch Window, and more
Virtual-Path configuration für Kubernetes installation
Hi,
I just test a Kubernetes Installation based on you documentation at https://github.com/ONLYOFFICE/Kubernetes-Docs and it works fine.
I used the nginx-ingress as described here: Expose DocumentServer via HTTP
But is there a way to expose it to a subdirectory like you described it here for a normal installation?
{{ if .Values.ingress.enabled }}
apiVersion: networking.k8s.io/v1
kind: Ingress
metadata:
  annotations:
    kubernetes.io/ingress.class: nginx
    nginx.ingress.kubernetes.io/proxy-body-size: 100m
    nginx.ingress.kubernetes.io/rewrite-target: /$2
    nginx.ingress.kubernetes.io/configuration-snippet: |
      proxy_set_header X-Forwarded-Host     $best_http_host/onlyoffice/;
spec:
  {{ if .Values.ingress.ssl.enabled }}
  tls:
  - hosts:
    - {{ .Values.ingress.ssl.host }}
    secretName: {{ .Values.ingress.ssl.secret }}
  {{ end }}
  rules:
  - host: {{ .Values.ingress.ssl.host }}
  {{ else }}
  - host:
  {{ end }}
    http:
      paths:
      - path: /onlyoffice(/|$)(.*)
        pathType: Prefix
        backend:
          service:
            port:
              number: 8888
{{ end }}
But it always redirects me to /welcome.
The Variable $best_http_host seems to be the dynamic hostname from the lua script in the generated nginx config in the nginx-ingress.
Best regards
Uli
Hi Uli,
Sorry, but we have no example configuration for virtual path in Nginx Ingress Controller.
As far as I understand, there were some issues with X-Forwarded-* headers which prevented us from creating such example config.
Hi Carl,
is it possible to modify your internal nginx configuration to support optimal the x-forwarded-prefix header?
Your relevant configuration in the kubernetes installation seems to look like this:
/tmp/proxy_nginx/includes/http-common.conf
map $http_host $this_host {
    "" $host;
    default $http_host;
map $http_x_forwarded_proto $the_scheme {
     default $http_x_forwarded_proto;
     "" $scheme;
map $http_x_forwarded_host $the_host {
    default $http_x_forwarded_host;
    "" $this_host;
map $http_upgrade $proxy_connection {
  default upgrade;
  "" close;
proxy_set_header Host $http_host;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection $proxy_connection;
proxy_set_header X-Forwarded-Host $the_host;
proxy_set_header X-Forwarded-Proto $the_scheme;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
The trick seems to be, that for virtual hosts, the path is a part of the x-Forwarded-Host.
For example:
Incoming Header: x-Forwarded-Host: demosystem.ch/onlyoffice
Transfered Header: x-Forwarded-Host: demosystem.ch/onlyoffice
The nginx will transfer this header unchanged to the docservice etc.
But maybe it is possible to merge the X-Forwarded-Host with the X-Forwarded-Prefix to the docservice so the Revers Proxy in the front can transfer the path information also as separate header.
For example:
Incoming Header: x-Forwarded-Prefix: /onlyoffice
So i think the config has to be changed to something like this:
    default $http_x_forwarded_host$http_x_forwarded_prefix;
    "" $this_host;
Background is, that Kubernetes ingress seems to support the X-Forwarded-Prefix better then the modified X-Forwarded-Host (as far as I understand, a kubernetes internal nginx lua script recalculate the X-Forwarded-Host header).
I test this in a “normal” windows installation and changed the Reverse Proxy to this header and it seems to work correctly in both cases (modified host and additional prefix).
Do you already check this solution?
Do this change has any disadvantages?
Hello together,
I just verified my guess. I create a own Dockerfile based on your onlyoffice/docs-proxy-de, just replace the file /etc/nginx/includes/http-common.conf and pushed the container on a private repository for testing.
Docker
DockerFile
FROM onlyoffice/docs-proxy-de:6.4.1.45
COPY http-common.conf /etc/nginx/includes/
http-common.conf
include /tmp/http-upstream.conf;
    "" $host;
    default $http_host;
     "" $scheme;
    "" $this_host;
  default upgrade;
  "" close;
The only change in the file is the following line:
Helm
Then on Helm side, I changed the ingresses\documentserver.yaml to the following:
kind: Ingress
metadata:
  annotations:
    nginx.ingress.kubernetes.io/x-forwarded-prefix: /onlyoffice
spec:
  tls:
  - hosts:
  {{ end }}
  rules:
  {{ else }}
  - host:
  {{ end }}
    http:
      paths:
        pathType: Prefix
        backend:
          service:
            port:
              number: 8888
{{ end }}
I changed the following lines:
It will be very nice if you can check and at my fix into your version of the container if possible.
Best regards
Uli
Hello Uli,
Thank you, we will take a look at this config file.
Hey, did you get this working?
@cwrau I still use a modified version of the original docker container and update it for each version. My docker image based on the original and just replace the configuration file.
I can post you a example for this if you need it.
@ONLYOFFICE: Is this still a open issue?
Yeah, the example would be great :+1:
Dockerfile
docs-proxy-de (docs-proxy-de Developer / docs-proxy-ee Enterprise) is the version you want to build.
7.1.1-4 Is the version of ONLYOFFICE you want to base on.
FROM onlyoffice/docs-proxy-de:7.1.1-4
http-common.conf (Modified as described)
    "" $host;
    default $http_host;
     "" $scheme;
    "" $this_host;
  default upgrade;
  "" close;
I build this via the local docker environment and push it to our Gitlab.
I think you can do the same thing with dockerhub and so on.
docker build -t registry.our-server:443/username/docs-proxy-de:7.1.1-4 .
docker push registry.our-server:443/username/docs-proxy-de:7.1.1-4
The last step is to replace the original docker container with your version in the values.yaml file of the ONLYOFFICE helm configuration.
proxy:
  proxyContainerImage: registry.our-server/username/docs-proxy-de:7.1.1-4
In our case we also need a authentication for our non open container registry.
But this is just a workaround and I hope ONLYOFFICE will fix this in a near future :slight_smile:
Hello @uwohlfeil and @cwrau
We are still working on it. As far as I know, there’s open ticket in Zendesk which was created by @uwohlfeil. My colleagues are still working on it and we will notify you when we have something to share.
Sorry for inconvenience.
Hallo @Alexandre ,
do you have any news about this issue?
Regards Uli
Hello @uwohlfeil
Please accept our sincere apologies. We are still working on it. My colleagues will contact you via Zendesk system when we have something to share.
Just hit the same issue… I suppose it affects every deployment of the document server container image behind a reverse proxy (i.e. nginx).
I am wondering if the config examples and related docs are valid for this kind of deployment.
Hello @davide.cavestro
We’re still looking into it. We will provide a solution as soon as possible.
Probably we found workaround solution. This is a temporary solution while we’re continuing to troubleshoot the situation, but it works.
We used mentioned http-common.conf file as an example and we changed it a little bit:
    "" $host;
    default $http_host;
     "" $scheme;
    "" $this_host;
  default upgrade;
  "" close;
proxy_set_header X-Forwarded-Prefix "/";
Also you have to add a few lines to values.yaml config file to annotations section.
Keep default lines and just add this:
    nginx.ingress.kubernetes.io/x-forwarded-prefix: /ds
      proxy_set_header X-Forwarded-Host     $best_http_host/ds;
Also go to templates/ingress/documentserver.yaml and add this line to -path: parameter:
/ds(/|$)(.*)
Please pay attention to ‘/ds’ value in my examples. You have to change it to your virtual path.
One more thing, we can’t guarantee that integrated example will work properly when these actions are performed. Also please prepare whole server backup\snapshot before any actions just in case.
Thanks, will try with the real app, as it fails for the example.
Please also consider passing the incoming headers when the ingress is trusted, as per proxy_pass_request_headers on.
I confirm it works like a charm on the iframe within the app.
We’re glad to be of service.
