In the previous version, you could run an Room Index report which shows you all the files in the VDR. With this new update, this doesn’t show, instead only shows folders. Is there a way to unlock this?
Hello @jmtomasz
Please specify the version that you are using.
Docs v.8.3.3.18
Docspace v.3.1.0
There is an update to version 3.1.1 is available, the fix has been deployed in this version. Please update your instance of DocSpace and check out the issue again.
UPD: Sorry for confusion, this version will be available later. Stay tuned.
