Using remote PostgreSQL
Hi,
I just installed OO Docs Community Edition on RedHat 8 and I would like to use database on remote server.
I tried to configure that with provided script documentserver-configure.sh but without success:
[root@onlyoffice ~]# documentserver-configure.sh
Configuring database access…
Host: sa-edb-edbsrvcl-efm:5444
Database name: onlyofficedb
User: onlyoffice
Password:
Trying to establish PostgreSQL connection… FAILURE
Manually I can reach database server
[root@onlyoffice ~]# psql -h sa-edb-edbsrvcl-efm -p 5444 -U onlyoffice -d onlyofficedb
Password for user onlyoffice:
psql (10.17, server 12.8.12)
WARNING: psql major version 10, server major version 12.
Some psql features might not work.
Type “help” for help.
onlyofficedb=>
What I’m doing wrong?
Hello ts989.
It looks like you got a conflict between versions of postgres database and server:
Please solve it and repeat the test.
One more thing. Please try to set database address as ip address while you are running documentserver-configure.sh
Hi Alexandre. Unfortunately, problem is still there
[root@onlyoffice data]# documentserver-configure.sh
Host: 10.170.68.84:5444
User: onlyoffice
Password:
[root@onlyoffice data]# psql -h sa-edb-edbsrvcl-efm -p 5444 -U onlyoffice -d onlyofficedb
psql (12.9, server 12.8.12)
WARNING: psql major version 12, server major version 12.
onlyofficedb=>
Hello ts989.
Please try to deploy remote database with default port 5432. After that run script one more time but do not set port number. It should look like this:
Host: 10.170.68.84
