Hello
I have a VM with Ubuntu 22.04, Openresty (instead of nginx), nextcloud and onlyoffice-document server.
Everything works fine, but I would like to pass to Ubuntu 24.04.
To do it I need to upgrade all package and onlyoffice-documentserver is one of them.
With an apt updte / apt upgrade, I get en error in onlyoffice-documentserver upgrade with the error in the --configure part.
I try to put latest version of onlyoffice-documentserver with the script “docs-install.sh”. (so it seem’s with .deb update.
It did not works neither
Same error :
dpkg: error processing package onlyoffice-documentserver (–configure):
installed onlyoffice-documentserver package post-installation script subprocess returned error exit status 1
What do you suggest ?
remove onlyoffice and upgrade to 24.04 and install it again?
try to upgrade it in 22.04
Any idea where the error could be with this errro message?
Is it link with the fact that onlyoffice works with nginx ?
Do I need to stop openresty, launch nginx during the install?
Thanks for the update! It’s great to hear that you were able to resolve the issue by temporarily switching between OpenResty and Nginx during the OnlyOffice update.
If you’d like to discuss the RabbitMQ issue further, feel free to create a separate topic and reference this one for context.
I search a little and find the way to upgrade rabbitMQ manualy befor pass to 24.04.
Everythings works now perfectly under 24.04
Onlyoffice
Nextcloud and Openresty
Will see in 26.04 if the nginx / openrety swith is still necessary
