Update Failure
Hi there, i try to update my onlyoffice-community-server to a newer one
with the script
bash workspace-install.sh -u true
After some time i got
stop container:
remove container:
check removed container: onlyoffice-community-server
unknown flag: --cgroupns
ONLYOFFICE COMMUNITY SERVER not installed.
And thats it?
A second try, i stop and removed the image and startet it again, now i am stuck in “We are working on it” :wink:
Any Ideas
Best regards
Michael
Hello @mediabw
Please provide us a link to the guide that you’ve used to install Workspace.
Did you use the same script that you’ve also used to install Workspace to update?
https://helpcenter.onlyoffice.com/installation/docs-community-update-docker.aspx
This is a link to the guide related to Document Server which is a different product.
Please double check the product that you are using at the moment.
