Originally published at: Unveil the power of automation with the ONLYOFFICE DocSpace and Slack integration via Zapier | ONLYOFFICE Blog
Good news for Slack users!
With a collection of ready-to-use templates available on the Zapier platform, now you can easily connect ONLYOFFICE DocSpace to your Slack and increase your productivity by automating some common routine tasks. Read this post to find out how this integration works and what you need to get started.
ONLYOFFICE DocSpace and Zapier integration
Zapier is a platform that helps you automate various repetitive tasks between two or more apps, without having to write code. Automation works via Zaps, automated workflows, created to follow a simple pattern: when an event happens in one app, Zapier makes another app to perform the required action.
Currently, the platform supports more than 7.000 apps allowing you to integrate your favourite apps into your daily work routine and automate various tasks, such as sending reminders before meetings and adding tasks to your to-do list.
ONLYOFFICE DocSpace has more than 70 ready-to-use Zaps for the most popular business platforms and productive apps, including Slack, Gmail, Trello, Zoom, HubSpot, Pipedrive, Discord and Asana. All these Zaps are available for free on the DocSpace page.
DocSpace Zaps for Slack
If you use Slack to communicate with your team, you can integrate ONLYOFFICE DocSpace via Zapier and automate your workflows. In this case, you don’t even need to create something new as there are some ready-to-use Zap templates for the following scenarios:
- Send Slack notifications for new ONLYOFFICE DocSpace files;
- Get Slack channel notifications for new ONLYOFFICE DocSpace users;
- Send Slack notifications for new users invited to ONLYOFFICE DocSpace rooms;
- Post Slack notifications for new ONLYOFFICE DocSpace rooms;
- Get Slack channel notifications for new folders in ONLYOFFICE DocSpace rooms;
- Relay Slack notifications for newly-archived ONLYOFFICE DocSpace rooms;
- Create Slack channels for new ONLYOFFICE DocSpace rooms;
- Create Slack channels for new ONLYOFFICE DocSpace folders;
- Invite new ONLYOFFICE DocSpace users to a Slack channe;
- Invite users to Slack channels when new users join ONLYOFFICE DocSpace rooms;
- Create folders in ONLYOFFICE DocSpace for new Slack channels;
- Create rooms in ONLYOFFICE DocSpace for new Slack channels;
- Add new Slack files to ONLYOFFICE DocSpace;
- Invite new Slack users to ONLYOFFICE DocSpace.
The ONLYOFFICE DocSpace and Slack integration via Zapier allows you to organize effective document management and collaboration while communicating with your teammates in Slack channels. Let’s find out how to connect DocSpace to your Slack and enable one of the templates above. For example, the one which allows us to receive a notification in our Slack channel when a new file is created in ONLYOFFICE DocSpace.
How to connect ONLYOFFICE DocSpace to Slack via Zapier
Step 1. First of all, you need to sign into your Zapier account or create a new one. It’s free to get started.
Step 2. Connect ONLYOFFICE DocSpace:
- Go to the Apps section on the left-side panel and click the + Add connection button in the upper right corner;
- Find ONLYOFFICE DocSpace;
- In the authorization window, enter the URL of your DocSpace, your email and password, and click the Yes, Continue to ONLYOFFICE DocSpace button.
Now ONLYOFFICE DocSpace is available in the list of your apps on Zapier.
Step 3. If Slack is not available in the list of your Zapier apps, add it following the instructions from the previous step.
Step 4. When both ONLYOFFICE DocSpace and Slack are added successfully, you can enable one of the Zap templates for this integration:
- Go to the ONLYOFFICE DocSpace page;
- Select Slack;
- Find the desired template and click the Details button;
- Click the Try this template button.
Step 5. Since you are using the ready-to-use template, it’s already configured but you can always change certain parameters depending on your needs. When you are ready with the ONLYOFFICE DocSpace trigger, you need to test it. If everything is OK, click Continue with selected record.
Step 6. Now it’s time to configure the Slack action. Check all the parameters and choose the required channel where you would like to receive notifications. After that, click the Test step button. If nothing goes wrong, and the test is successful, you can click the Publish button.
That’s it. Our Zap is ready, and now you will always receive notifications in your Slack channel if a new file is created in your DocSpace.
Let’s get back to our Slack channel. As you can see, there is a new notification sent by the ONLYOFFICE bot. Now we know that a new file has been created in our DocSpace, and we can easily access this file by clicking the link in the notification, which is very convenient.
This way, you can enable the other DocSpace templates and even create new unique Zaps depending on your needs.
Get started with ONLYOFFICE DocSpace
Create a free DocSpace account right now and connect it to thousands of productivity and business apps on Zapier to bring automation to your workflows and get rid of repetitive manual tasks:
