Untick "Always Show Toolbar" and "Status Bar" by default
Hi, how can i disable 2 settings in red field by using API’s editorConfig option?
Hello @ZangHoang
Please clarify which product you are using. Initialization config is available for on-premise installation of Document Server, however, you’ve set the category as “Desktop Editors”.
Im using OnlyOffice Server with developer edition. About the tag of this thread, seem like i have some mistake in here, sorry about that. By the way, can i hide the “Status Bar” by using this config API like this Config - ONLYOFFICE Api Documentation.
If you a have active or trial license for Developer Edition of Document Server, I’d recommend contacting my colleagues via Helpdesk to get precise information and prompter responses.
As for the request: you can utilize compactToolbar to hide the toolbar, but status bar cannot be hidden as far as I know. You can specify details about status bar via Helpdesk.
