This may sound foolish, but I have searched through the documentation and cannot find the API for setting the outline level. Could you please help me find it
Hello @nichaoshou
Please specify what you want to outline in the first place.
May I ask if there is an API for setting the outline level
There are lots of elements that inherit their own way of setting outline levels.
For example, outline level for a text passage in the run can be set via these methods:
- SetOutLine for document editor;
- SetOutLine for spreadsheet editor;
- SetOutLine for presentation editor.
For even more examples, here are several methods to outline elements of a chart:
As you can see there are plenty of elements to set outline for, that is why I asked what do you want to outline exactly and where, with this information I can find a suitable for you method.
What I want to achieve is to create an outline level for my custom style in the plugin, as shown in the picture
Thanks for clarifying.
I am looking for the needed method, once I find anything I’ll let you know.
