Hi, I’m working in the presentation mode of only office and am unable to Color fill Freeform shapes I draw. The command to do this is greyed out. Regular shapes are able to be filled without a problem. Any advice would be welcome. Thank you
Hello @Mistere
What is freeform shape that you are referring to? Do you mean a shape that you can draw?
Hi Constantine, yep the Freeform shape is the hand drawn option at the bottom of the shapes choices. It is next to the scribble option. All other regular shapes can be filled. It is available for presentations and word type documents but the Color fill command for Freeform is greyed out.
Please share a test file with your freeform for the reference.
Hi Constantine, thanks for getting back to me. I’m running OnlyOffice on a Macbook Pro. I tried to attach a test file created on the Mac, however as a new user I don’t have this feature yet. Instead, I’ve included a link to the file on Google drive. Thanks for any help you can offer.
Pete
Freeform test
Unfortunately, the link returns 401 Unauthorized. Can you upload your file to any other cloud storage to share a link?
