docker ps
root@only:~# docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS
NAMES
68443b43c6ed onlyoffice/communityserver:12.0.0.1726 "/app/run-community-…" 16 hours ago Up 3 minutes 0.0.0.0:80->80/tcp, :::80->80/tcp, 0.0.0.0:443->443/tcp, :::443->443/tcp, 3306/tcp, 5280/tcp, 9865-9866/tcp, 9871/tcp, 9882/tcp, 0.0.0.0:5222->5222/tcp, :::5222->5222/tcp, 9888/tcp onlyoffice-community-server
b88399cb3ecc onlyoffice/controlpanel:3.1.0.460 "/var/www/onlyoffice…" 16 hours ago Up 3 minutes 80/tcp, 443/tcp
onlyoffice-control-panel
40071a60275f onlyoffice/elasticsearch:7.10.0 "/tini -- /usr/local…" 16 hours ago Up 3 minutes 9200/tcp, 9300/tcp
onlyoffice-elasticsearch
b32be3f015c4 onlyoffice/documentserver:7.1.0.215 "/app/ds/run-documen…" 3 days ago Up 3 minutes 80/tcp, 443/tcp
onlyoffice-document-server
12fb223af65f mysql:8.0 "docker-entrypoint.s…" 3 days ago Up 3 minutes 3306/tcp, 33060/tcp
onlyoffice-mysql-server
root@only:~# docker exec -it onlyoffice-community-server service monoserve status
● monoserve.service - FastCGI Mono server
Loaded: loaded (/lib/systemd/system/monoserve.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2022-05-26 14:58:34 UTC; 19s ago
Process: 2684 ExecStartPre=/bin/bash -c test -e /var/run/onlyoffice || install -m 755 -o onlyoffice -g nginx -d /var/run/onlyoffice; rm -f /var/run/onlyoffice/onlyoffice.socket /var/www/onlyoffice/WebStudio/mono_crash* /var/www/onlyoffice/WebStudio/core.*; (code=exited, status=0/SUCCESS)
Main PID: 2686 (mono)
Tasks: 38 (limit: 9445)
CGroup: /docker/68443b43c6ed704addd50d6a3db44ce256835d75403368a451dca9f116f0e765/system.slice/monoserve.service
└─2686 /usr/bin/mono /usr/lib/hyperfastcgi/4.0/HyperFastCgi.exe /config=/etc/hyperfastcgi/onlyoffice /logfile=/var/log/onlyoffice/onlyoffice.log /loglevels=Error
May 26 14:58:51 68443b43c6ed hyperfastcgi4[2686]: at ASC.Core.TenantManager.GetTenant (System.String domain) [0x0001f] in <93536df5eb3141aa902bfdaa852a8256>:0
May 26 14:58:51 68443b43c6ed hyperfastcgi4[2686]: at ASC.Core.TenantManager.GetCurrentTenant (System.Boolean throwIfNotFound) [0x00047] in <93536df5eb3141aa902bfdaa852a8256>:0
May 26 14:58:51 68443b43c6ed hyperfastcgi4[2686]: at ASC.Common.Logging.LogManager+<>c.<GetLogger>b__0_0 () [0x00005]
May 26 14:58:51 68443b43c6ed hyperfastcgi4[2686]: at ASC.Common.Logging.LogNLog.Log (NLog.LogEventInfo theEvent) [0x00008] in <6f90ed990ebe4efd8a7198e273998c87>:0
May 26 14:58:51 68443b43c6ed hyperfastcgi4[2686]: at ASC.Common.Logging.LogNLog.Log (NLog.LogLevel level, System.Object message) [0x00025] in <6f90ed990ebe4efd8a7198e273998c87>:0
May 26 14:58:51 68443b43c6ed hyperfastcgi4[2686]: at ASC.Common.Logging.LogNLog.Error (System.Object message) [0x00000] in <6f90ed990ebe4efd8a7198e273998c87>:0
May 26 14:58:51 68443b43c6ed hyperfastcgi4[2686]: at ASC.Api.ApiSetupHttpModule.Init (System.Web.HttpApplication context) [0x00053] in <3a3ad8ee38e349eba3ee312f3b4e1ec4>:0
May 26 14:58:51 68443b43c6ed hyperfastcgi4[2686]: at System.Web.Configuration.HttpModulesSection.LoadModules (System.Web.HttpApplication app) [0x00047] in <ed5a28140a7245099ac6474902196c2e>:0
May 26 14:58:51 68443b43c6ed hyperfastcgi4[2686]: at System.Web.HttpApplication.InitOnce (System.Boolean full_init) [0x0008e] in <ed5a28140a7245099ac6474902196c2e>:0
May 26 14:58:51 68443b43c6ed hyperfastcgi4[2686]: Please restart your app to unlock it
