When opening a pdf file in OO, left panel is shown even when option “Left Panel” is turned off. I have named the video “left panel 1”.
When checking the option “Left Panel” and exiting OO pdf file, and entering OO pdf file again, option “Left Panel” gets unchecked. I have named the video “left panel 2”.
Thanks
OS version: Windows 10 Pro 22H2
App version: 8.0.0.99 (x64 exe)
Hello @nicesto
Please note that newer version of Desktop Editors is available. Please update your app to actual version, check the situation again and provide us a feedback on the issue.
If issue is reproducible after the update, please try resetting cache of the app by removing following folder or the content in it:
C:\Users\username\AppData\Local\ONLYOFFICE\DesktopEditors\data\cache\Local Storage
Note that it will also remove all files from Recent tab and connections from Connect to cloud menu.
After that try unchecking Left Panel box and re-opening the file.
